MHB Solving word problems using a system of equations (i'm guessing simultaneous).
The discussion revolves around calculating the length of a road built with yellow and green bricks, where there are 12,000 yellow bricks and a ratio of 3 yellow bricks for every green brick. It is established that the number of green bricks is 4,000, leading to a total of 16,000 bricks. Each brick measures 500mm x 250mm, equating to 1/8 square meter, which means 8 bricks fit into one square meter. Consequently, the total area covered by the bricks is 2,000 square meters, resulting in a road length of 2,000 meters. The conversation also touches on the need for simultaneous equations to solve the problem, although some participants question the necessity of this approach.
Daps
you are laying the yellow and green brick road. the road is 1m wide and each brick is 500mm x 250mm. there are 3yellow bricks for every green brick. the road will be built with 12000 yellow bricks .how long will the road be?
Let x represent the no of yellow bricks
Let y represent the no of green bricks
I managed to get that x=3y-----equation 1
couldn't work equation 2 even though i could infer that y to be 4000bricks.
the 500mm x250mm brick (i'm thinking 8 of them is needed to fit into a square meter.
please can anyone enlighten me.
thanks
Mathematics news on Phys.org
thanks
12000 yellow + 4000 green = 16000 bricks total
8 bricks for every square meter
16000/8 = 2000 square meters = 1 meter x 2000 meters
skeeter, thanks for your take on this question.sorry how did you work out they are suppose to have 8 bricks to fit in 1 square meter.
secondly what are the systems of equations (probably 2 equations).needed here.
Thanks replies are welcomed from everybody.
given brick dimensions ...
500mm x 250mm = 0.5 m x 0.25 = 1/2 m x 1/4 m = 1/8 square meter
8 bricks x 1/8 square meter per brick = 1 square metersimultaneous equations? why make it more difficult?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
