Solving x''(t)+Kx(t)=0 when x has the form sin(ωt+ø): the soln r LD
  • Thread starter Thread starter gikiian
    Form
gikiian
I have the ODE x''(t)+\frac{k}{m}x(t)=0.
Given that the solution is of the form sin(ωt+ø), I plug this form into the original ODE and obtain ω=+\sqrt\frac{k}{m},-\sqrt\frac{k}{m}.
And hence, I obtain two solutions of the ODE as follows:
x_{1}(t)=Asin(\sqrt\frac{k}{m}t+ø), x_{2}(t)=Bsin(-\sqrt\frac{k}{m}t+ø)
Next, I check for the linear independence of the two solutions using the 2x2 Wronskian matrix and obtain Wronskian=-2ωsin(ø) which vanishes at ø=0 or ω=0, implying that the two solutions are not linearly independent.
How can I find the second solution of the second order ODE?
The two solutions are not necessarily with the same ø
x_{1}(t)=Asin(\sqrt\frac{k}{m}t+ø_1), x_{2}(t)=Bsin(-\sqrt\frac{k}{m}t+ø_2)
The general solution of x'' + \omega^2x =0 is
x = A\cos (\omega t)+ B\sin (\omega t)
By use of the sum formulae for sine and cosine this can be written as either
<br /> x = R \cos (\omega t + \phi)<br />
where R^2 = A^2 + B^2, \cos \phi = A and \sin\phi = -B, or as
<br /> x = R \sin (\omega t + \theta)<br />
where R^2 = A^2 + B^2, \cos \theta = B and \sin\theta = A.
The point is that the general solution has two parameters: either two amplitudes or an amplitude and a phase shift.
gikiian said:
I have the ODE <br /> <br /> Next, I check for the linear independence of the two solutions using the 2x2 Wronskian matrix and obtain Wronskian=-2ωsin(ø) which vanishes at ø=0 or ω=0, implying that the two solutions are not linearly independent.<br />
<br /> <br /> 1) If two functions are linearly dependent, then the Wronskian will vanish everywhere. <br /> <br /> 2) If the Wronskian is not zero at any point, then the functions must be linearly independent.<br /> <br /> So, your two functions are linearly independent unless w = 0 or ø is a multiple of pi.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
