Some basic electric potential questions
The discussion revolves around calculating the electric potential of a hydrogen atom's nucleus at the electron's mean distance. The user initially used the wrong atomic radius of 25 x 10^(-12) meters, leading to an incorrect potential value. They referenced the formula V = kq/r for their calculations. Ultimately, they corrected their approach by using the correct radius of 5.29 x 10^(-11) meters, which resolved their issue. The thread highlights the importance of using accurate values in physics calculations.
kyoko
[solved] some basic electric potential questions
Find the electric potential established by the nucleus of a hydrogen atom at the mean distance of the circulating electron.
V = - Integral of (E (dot) dL)
V = kq/r from r distance of a point charge
well, I found on wikipedia that the atomic radius of a hydrogen atom is 25 * 10 ^ (-12) meters.
So I just used kq/r to find the potential and got the wrong answer.
Should I be using a different distance or a different equation?
thanks
nvm I solved it I had to use r=5.29 * 10 ^ (-11) meters
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
