Phantasm
- 24
Hey guys,
I'm still working away on some projects I've been building/studying. I'm not actually building any practical circuitry but just experimenting with some results...
Anyway - I've discovered that domain realignment within iron cores in high frequency solenoids can be too slow to keep up with the high frequencies.
I am wondering what kind of conventional core material you can suggest that can realign its domains in the 500khz ballpark
Using straight iron cores gives me great results for magnetic flux being held within the core, but Iron domains are too slow to re-align at 500khz
I've been reading around and I've read a bit about steel mixed with silicon to allow for higher frequency domain realignment... Am I on the right track? I wasnt able to determine if this stuff would have the same performance with magnetic flux though.
Someone pointed me at making my own custom cores using fine grain iron filings and 2 component foam... but again, Not sure what kind of results that might yield.
Yet another suggestion I've received was to use copper rods or copper tubes. And a final suggestion was to use copper tubing with solid aluminum cores (Insert aluminum dowel into copper refridgeration tubing). I am skeptical of these last suggestions as I know that copper and alulminum are not ferromagnetic but I was not able to discover much information about how copper or a copper/aluminum mix would behave as a core material in a solenoid.
I suppose I can try all of these ideas, but in the interest of saving $$ I would greatly appreaciate any suggestions for a core material that can derive a strong & clean magnetic field while undergoing high frequency repolarization
Thanks very much in advance for your consideration!
Cheers,
Cheers,
