Sound and air movement: do they affect each other?
In summary: However, if you create a flow of air in front of a speaker playing some music, the pressure difference between the compressed air and the surrounding air will cause the sound waves to be concentrated in front of the speaker.
fisico30
374
Hello Forum.
I have two basic sound questions:
I know sound (large wavelength) diffracts a lot when it exits an aperture. But if someone is speaking and he/she is not facing us we still hear them, even if we are in an empty field.
Does sound diffract so much that it ends up even behind us?
2. If we created a flow of compressed air in front of a speaker playing some music, would the receiving microphone simply detect the noise from the compressed air or would the compressed air disrupt the air molecule behavior (sound coming out of the speakers) and change it?
After all, sound is simply compressions and rarefactions of air density, i.e. molecules that bump into each other...
If we push some air in front of the microphone we should be able to randomize the air molecules motion and not here the music...
thanks,
fisico30
Sound can get carried by air movement.
You can hear this on a windy day if you walk around someone speaking.
I'm not sure that all the sound you hear behind someone speaking in still air is the result of diffraction alone. The human voice is not a single point source.
Flowing air has a lower pressure than still air. So if you blow air at or across the speaker it will experience a lower pressure than if you didn't.
Well, when someone speaks the aperture is his/her mouth. It would seem that sound would move forward, in a hemispherical region of space...but not be present in region behind the the person speaking...
Reflections have an effect, but if we are in the middle of a football field we still hear a person's voice even if they are not facing us...How do air molecules get to vibrate behind the person speaking?
If you look at the acoustic radiation pattern of many chamber type sources you will see the characteristic 'doublet pattern' (figure of eight).
Don't forget that the back of the head/throat/chest is not a very good acoustic barrier.
Sound emitted by a point source (not exactly someone's mouth, but similiar) the sound energy spreads shperically...that is, in all directions.
Related to Sound and air movement: do they affect each other?
1. How does sound travel through air?
Sound is a form of energy that travels in the form of waves. When an object vibrates, it creates a disturbance in the air molecules, which then move in a wave-like pattern. These waves travel through the air until they reach our ears, where they are perceived as sound.
2. Can sound affect the movement of air?
Yes, sound can affect the movement of air. When sound waves travel through air, they cause the air molecules to vibrate, which in turn creates areas of high and low pressure. This can result in the movement of air particles, which we can feel as wind or air currents.
3. How does the speed of sound relate to air movement?
The speed of sound in air is affected by the temperature and humidity of the air. As air temperature increases, the speed of sound also increases. This means that in warmer air, sound waves can travel faster, causing more movement of air particles.
4. Can certain frequencies of sound create stronger air movement?
Yes, certain frequencies of sound can create stronger air movement. This is because different frequencies of sound have different wavelengths, and longer wavelengths can create more powerful vibrations in the air molecules. For example, low frequency sounds such as thunder can create stronger air movements than high frequency sounds like a whistle.
5. How does air movement affect the perception of sound?
Air movement can affect the perception of sound in several ways. First, it can change the direction and intensity of sound waves, which can alter how we hear a sound. Additionally, strong air movements, such as wind, can create background noise that can make it more difficult to hear certain sounds. Finally, air movement can also affect the speed of sound, which can impact the timing and clarity of the sound we hear.
  • DIY Projects
9K
