Sound intensity and ocean microphone
The discussion centers on calculating the distance a porpoise can be from a microphone in the ocean while still being heard, given the microphone's sensitivity to sound intensity at 10.6 dB. The initial calculation mistakenly used an intensity value that was ten times too high, leading to an incorrect distance of 5.89E+3 meters. The correct intensity, derived from the dB formula, is 1.148E-11 W/m^2, resulting in a distance of approximately 1.87E+4 meters when applying the formula for intensity. The error was identified as a miscalculation of the intensity value used in the formula. Accurate calculations are crucial for determining sound detection ranges in underwater environments.
Corky
The problem states:
A microphone in the ocean is sensitive to sounds emitted by popoises. To produce a usable signal , sound waves striking the microphone must have an intesity of 10.6 dB. If porpoises emit sound waves with a power of 0.0502 W, how far can a porpoise be from the microphone and still be heard? Disregard ansorbtion of sound waves by water.
I tried putting 10.6 decibels in the equation dB=10Log(I/Io)
and I solved for intensity to be 1.148E-10W/m^2
I then used that number in the I = P/4pi r^2 formula.
Solving for r I got 5.89E+3m.
But the right answer it the book is 1.87E+4
Can anyone tell me where I went wrong??
10log(I/(10^-12)) = 10.6
log(I/(10^-12)) = 1.06
I/(10^-12) = 10^1.06
I = 1.148e-11
I = P/(4pi r^2)
r^2 = P/(4pi I)
r^2 = 0.0502/(4pi 1.148e-11)
r^2 = 3.4797e8
r = 18654m
r = 1.87e4
I think the error was in what you thought the value for I was. Your I is 10x as big as mine.
Nice thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
