Source transformations doesn't always produce same result?
Source transformations can change circuit behavior, particularly in RC circuits. In a series RC circuit with a DC voltage source, once the capacitor is fully charged, all voltage is across the capacitor and no current flows. However, when transforming to a parallel RC circuit with a DC current source, current continues to flow through the resistor, resulting in voltage across both components. The final voltage across the parallel setup is determined by the current times the resistance, confirming the voltage would be 30 V in the given example. Understanding these nuances is crucial for accurate circuit analysis.
eng_stud
I was under the impression that a source transformation doesn't change a circuit at all, which I guess is an oversimplification.
If you have a series RC circuit, with a DC voltage source, after the transients have died out, all voltage will be across the capacitor, and none across the resistor, as there is no current flowing anymore (when cap is fully "charged"), right?
If you now do a source transformation, changing the DC voltage source to a DC current source, with the resistor in parallel, you now have a parallel RC circuit with a DC current source. Now, surely, current will never cease as it has another path through the resistor. So after the capacitor is charged, all current goes through the resistor. So in this case there's voltage across both the resistor and capacitor?
This might all be incredibly obvious. I just want to make sure there is nothing here that I have misunderstood!:)
Follow-up question: If you have a circuit with a 10 A dc current source, with a 3 Ohm resistor and a 0.02 F capacitor in parallel, what determines the resulting voltage across the parallel setup? When the capacitor is fully charged? Or the voltage that would have been the source had we done a source transformation? (i.e. v=ir=10*3=30 V across both components).
I'm assuming the latter?
Your understanding in both posts is correct. With a current source, a resistor and capacitor in parallel the final source voltage will be equal to the current times the resistance.
Thanks, skeptic2!
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
