Space-invariant means homogeneous
In summary: Euler's theorem says that if you have a function that is differentiable everywhere, then the derivative is also differentiable everywhere. That means that if you have two differentiable functions and you want to find a function that is between them, the function you get is going to be differentiable everywhere.So what is invariant, what stays the same about equations?We could also have invariance of objects with respect to a frame of reference, if the different frames are all inertial (moving at constant speed).
fisico30
374
The concept of invariance of an object, property, etc... should always expresses with respect to something else:
time-invariant means static.
space-invariant means homogeneous.
direction invariant means isotropic.
"Something" can have just one of those types of invariance, all three of them, or none.
When talking about a vectors, a functions, formulas and equations I hear that they need to be invariant in the sense that they are independent of the coordinate system used to express them. A coordinate system is just a different way to describe the same phenomena (usually a simpler, more convenient way).
A vector, upon change of coord system, changes its description but its magnitude and true direction is always the same.
But when I think about equations, say the Helmholtz equation, when changing from Cartesian to spherical coord., the equation changes its functional form completely...
So what is actually invariant, what stays the same as far as equations goes?
For ex: F=ma equation has the same form in another frame F'=ma'...
thanks
fisico30
Under Lorentz transformations, 4 vectors are invariant, but 3 vectors are not. E and B 3-vectors are not invariant, but the 4-potential is. Maxwell's equations in their usual form are also not "manifestly covariant", but they can be written in a different way so that their form does not change under a Lorentz transformation.
Take a look at Woodhouse's Lecture 12:
http://people.maths.ox.ac.uk/~nwoodh/sr/index.html
Box A is always zero.
Related to Space-invariant means homogeneous
1. What does it mean for something to be space-invariant?
Space-invariant means that a property, characteristic, or behavior remains consistent regardless of its position or location within a given space. In other words, it is independent of spatial coordinates.
2. How is space-invariance related to homogeneity?
Space-invariance and homogeneity are closely related concepts. In fact, they are often used interchangeably. Homogeneity refers to the uniformity or sameness of a property or behavior throughout a given space, which is a key aspect of space-invariance.
3. Can you give an example of a space-invariant property?
One example of a space-invariant property is gravity. Regardless of where an object is located in space, it will always experience the same force of gravity. Another example is the speed of light, which remains constant regardless of the observer's position.
4. How is space-invariance important in scientific research?
Space-invariance is crucial in scientific research because it allows for generalization and prediction. By assuming that a property or behavior is consistent throughout a given space, scientists can make accurate predictions and draw conclusions that apply beyond the specific location or conditions of their experiments.
5. Are there any limitations to space-invariance?
While space-invariance is a useful concept, it is not always applicable in every situation. Certain phenomena or systems may exhibit non-uniformity or variations in different regions of space, making it difficult to assume space-invariance. Additionally, space-invariance does not take into account the effects of time or changes in conditions.
