Spacelike hyperbolae -- accelerated reference frames
In summary: This point is called the vertex of the hyperbola.Correct. The foci are further away from the centre than the point where a hyperbola of the form ##t^2-x^2=-k^2## intersects the ##t## axis (the point ##(0, -k)##). This point is called the vertex of the hyperbola.
smodak
459
253
Uniformly accelerated reference frames in special relativity are represented in the space-like region of a lightcone as hyperbolae. These hyperbolae represent worldline of accelerated observers. However, there could not be be causal relationship between two events on the spacelike section unless information travels faster than light. Shouldn't that mean accelerated ref frames represent faster than light travel? What am I missing?
This is not correct. The hyperbolas representing the worldlines of accelerated observers are timelike, not spacelike. Your terminology, describing the "right wedge" of Minkowski spacetime as "the spacelike region", is misleading you; not all pairs of events in this region are spacelike separated. They are all spacelike separated from the origin (the apex of the light cone), but that's not the same thing.
Likes smodak
I think I get it. Thank you!
Consider the reference frame of an unaccelerated observer in flat space-time. You can draw the worldlines of observers - they're straight lines rather than hyperbola - but you can make the same remark about space-like separated events not having a causal relationship.
But I don't understand how you are interpreting these facts (which apply to an unaccelerated observer as well as an accelerated one) as faster than light travel. Everything you've said applies equally well to an inertial frame.
You are right. PeterDonis corrected my confusion. For some strange reason, I was making a connection that does not exist. Thanks for the help!
Note that the hyperbolae of the form ##t^2-x^2=k^2## (not ##-k^2##) are space-like, but they do not describe world lines of accelerated observers and have time like separation from the origin.
Not sure I understand that. I thought the Rindler Hyperbolea of the form ##t^2-x^2=k^2## represent uniformly accelerated reference frames.
No, those would be the hyperbolae ##x^2-t^2=k^2##.
Likes smodak
They do if ##k^2## is negative, in the form you've written it; the more usual form is ##x^2 - t^2 = k^2##, where ##k^2## is positive (and is equal to ##1 / a^2##, where ##a## is the proper acceleration of the worldline), because it is usually assumed that we are working with real numbers only.
Hyperbolas of the form ##t^2 - x^2 = k^2## where ##k^2## is positive are in the future or past light cones of the origin; they represent sets of events that are at the same proper time from the origin.
Likes smodak
smodak said:
What am I missing?
The hyperbolae in those diagrams are each shifted so that they share a common focus at (I think) $$x = -1 / a $$ the even horizon. If you un-shift each one to pass throught the origin, it is easy to see that they are always timelike.
x = -1 / a
the even horizon.
The focus of the hyperbolas is at the spacetime origin, ##x = t = 0##. Also, the horizon in this case (which is the lines ##x = \pm t##, the asymptotes of the hyperbolas) is not an event horizon; it's the Rindler horizon.
No they are not. You are thinking of the centre of the hyperbolas. The foci of the hyperbolae tend to ##x\to \pm \infty## as the proper acceleration goes to zero.
Oops, yes, you're right.
This means the hyperbolas don't all have the same focus, even though they all have the same center, correct?
Sorry folks, I messed that up! How about they are all shifted by$$+1/a$$ so that they share a common centre at the origin? If that is wrong then I give up . . . ;)
Despite my history of early morning posts when going to work - I do try some times :-p
Edit: Also, I cheated. I discussed hyperbolic trajectories in a Kepler potential recently so I rehearsed the terminology ...
Correct. The foci are further away from the centre than the point where a hyperbola crosses the x-axis.
Well, it depends on what you mean by "shifted". They share the same centre so in that respect they are not shifted at all ... However, you need to shift them from there in order for them to go through the origin. But yes, in that respect they are shifted relative to where they would be if they all went through the origin.
Yes, I only meant in the sense that a constant velocity line is typically drawn through the origin when illustrating its slope wrt light. I thought that was really what the OP was asking when he mentioned that accelerated world lines occupied the "space-like" zone.
Thanks everyone for replying. Now a different question. If you are staying on a specific hyperbola and asymptotically moving up towards x= t (or x = ct), you are not moving through space just through time, right? Where is the acceleration coming from? Is it only a temporal acceleration with no spatial acceleration? If, so, how then these coordinates represent accelerating reference frames in general?
There is no such thing in an absolute sense; whether or not you are "moving through space" or not depends on the coordinates you choose. In inertial coordinates, you are "moving through space" if your worldline is one of these hyperbolas; in Rindler coordinates, you're not.
Sorry, I'm not really following the question :(.
Any observer, accelerating or not, has some worldline that represents their history through space and time.
If we create some inertial frame of reference S, then in that inertial frame S a non-accelerating observer moves along a straight line. This can be regarded as a tautology rather than any law of physics - we can regard it as defining what an "inertial frame of reference" means in operational terms.
I can't quite figure out what you're doing or asking here, my closest guess is that you're confused about what the difference between an accelerating frame of reference and an inertial frame of reference is. If we ignore gravity for the time being, imagining that we are out far enough from any massive body so gravity is not important, then we can regard the motion of a force-free body as sort of test. If the force-free, isolated body moves in a straight line, we have created an inertial frame of reference. If the force-free, isolated body does not move in a straight line, then we have not created an inertial frame of reference, we've created a non-inertial frame of reference.
Note that we (or at least I) regard a frame of reference as something we create, a human invention, not something that is "handed to us" or has any reality on its own. I suspect you may be coming from some other philosophical viewpoint, but I don't quite understand what that viewpoint may be, or how to reconcile your viewpoint (whatever it is) with mine so that we can meaningfully talk about physical facts.
[add]
I talked about what happens if we ignore gravity. If gravity is part of the question, things just get more complicated. Strictly speaking, inertial frames of reference simply don't exist if you have gravity. Non-strictly speaking, thigns aren't quite so bad, but I won't digress into that, I think we have enough to sort out already.
I think both of you have answered my question. Uniformly accelerated particles undergo hyperbolic motion in minkowski space in inertial coordinates. When you use Rindler coordinates, they are actually at rest. Thank you!
Great Stuff. Thanks.
FAQ: Spacelike hyperbolae -- accelerated reference frames
1. What are spacelike hyperbolae?
Spacelike hyperbolae are a type of hyperbolic curve that can be described in three-dimensional space. They are characterized by the equation x2/a2 - y2/b2 = 1, where a and b are constants. These curves have a hyperbolic shape and are important in the study of spacetime and accelerated reference frames.
2. How are spacelike hyperbolae related to accelerated reference frames?
In the study of special relativity, spacelike hyperbolae are used to describe the worldlines of objects in accelerated reference frames. These curves represent the paths of objects that are constantly accelerating, and they play a crucial role in understanding the effects of acceleration on time and space.
3. What is the significance of studying accelerated reference frames?
Studying accelerated reference frames is important because it helps us understand the behavior of objects in non-inertial frames of reference. In everyday life, we often experience acceleration, and understanding its effects is essential for engineering and physics applications.
4. How can spacelike hyperbolae be visualized?
Spacelike hyperbolae can be visualized in three-dimensional space by plotting their equation on a graph. They will appear as hyperbolic curves that extend infinitely in both directions. In the study of special relativity, they are often represented on Minkowski diagrams, which use spacetime coordinates to depict the relationship between space and time.
5. What are some real-world examples of accelerated reference frames?
Some examples of accelerated reference frames include a car turning around a curve, a rollercoaster, and a rocket taking off. In these situations, objects experience a constantly changing acceleration, and their worldlines can be described by spacelike hyperbolae. Understanding how acceleration affects time and space is crucial for designing safe and efficient transportation systems and space travel.
