- 10,413
- 1,588
PeterDonis said:Yes. And you can also point exactly opposite from that direction and point away from the hole.
And inside the hole, independent of your state of motion, you can point away from the hole. So you can also point exactly opposite from that direction and point towards the singularity. (Note that this is true even though the singularity is in your future--there are always timelike, null, and spacelike directions that point towards the singularity.) As I said, there is always a spacelike radial direction you can point in.
I haven't read the entire thread, but this remark caught my interest when I was skimming it.
In order to evaluate this statement, which seems counter-intuitive, I'd need to translate it into a mathematical format. Specifically, what does "point towards" and "point away" mean in a formal, mathematical sense?
My attempt at interpreting this remark involves some context. This context is the time-like worldline some infalling observer, which I would tend to assume for simplicity is a geodesic worldline of an infalling observer that started outside the event horizon (r > r_s, r_s being the schwarzchild radius, in region I of the kruskal diagram if we introduce an extended manifold), and terminates at the singularity (r=0), using for convenience the Schwarzschild coordinates. To further simplify, I'd assume it's a radially infalling observer (theta and phi in the Schwarzschild coordinates are constant).
We can set up an orthonormal set of basis vectors in the tangent space of some event, with the local concept of "space" in the tangent space being generated by vectors that are orthogonal to the time-like vector generated by the worldline.
We are then inquiring as to whether or not the geodesic curves generated by said tangent vectors from the initial specified event intersect r=0, or r = r_s, the Schwarzschild radius.
This formalizes the concept of "pointing towards" in a formal sense, but it's unclear if that's what you meant to say.
The answer, at this point, is not particularly obvious. I'd like to know if you consider this a fair re-statement of the problem in formal terms so that it has a definite answer.
It shouldn't be too terribly difficult to set up the appropriate differential equation parameterized by some affine parameter s, I imagine one can use some of the usual references for time-like geodesics by taking into account the sign change from time-like to space-like.
