Spanning Sets in Vector Spaces
mlb2358
True or False: If S is a spanning set for a vector space V, then every vector v in V must be uniquely expressible as a linear combination of the vectors in S.
For some reason, the answer to this question is false, although to me it seems like this is almost the definition of a spanning set. I am unsure about what the word "uniquely" means here, so maybe that is causing my confusion. Any help would be appreciated!
I think you're onto it, but i'd go back to your definition of a spanning set. If it only requires that the set spans V and uniqueness is not required, then there may exist more than one way to form a given vector v, e.g. consider if your set had both (1,0,0) and (2,0,0) in it..
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
