SPDT switches in CMOS processes.
  • Thread starter Thread starter Lanot
    Cmos Switches
The discussion centers on designing a Single Pole Double Throw (SPDT) switch using CMOS processes. The initial design employs two transmission gates and a MOS inverter, but concerns are raised about the introduction of parasitics from multiple switches. Alternatives are suggested, such as using two N-channel FETs for specific grounding applications, depending on the switching requirements. The effectiveness of the circuit is contingent on the specific signal characteristics, particularly if the signal swings between ground and VDD. A schematic of the proposed design would facilitate a more tailored solution.
Lanot
Hi guys,
Recently I had to design a SPDT switch for a project, which I was able to design using the trivial circuit with 2 transmission gates and 1 MOS inverter, like this: http://www.semicon.toshiba.co.jp/eng/product/new_products/logic/1326183_37648.html
I think that this circuit is not optimal, since it introduces the parasitics from two switches.
The question is: Is there a better circuit to do this?
Thank you.
That is optimal if you want bi-directional switching of arbitrary signals between VDD and VSS.
If you switching requirements are different, you may get away with two fets. For example if all you want to do is ground 1 line or the other you can use 2 N channel FETs to ground. etc etc etc
It depends on exactly you are trying to do.
Yes, you are correct.
The signal in question may swing from ground to vdd though. So isn't there a better approach?
Again, it depends on exactly what you are doing. A schematic would help.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
