Special relativity homework question time dilation
The discussion revolves around a homework problem involving time dilation in special relativity, where a spaceship travels at 95% of the speed of light to Altair, 17 light years away. The key equation for time dilation is Δtmoving = Δtrest x [square root of (1−v^2/c^2)]. Participants clarify that the problem seeks the biological age of the passenger upon arrival, which requires calculating the time experienced on the spaceship. The solution involves determining the time taken according to Earth observers and then applying the time dilation equation to find the passenger's age. Ultimately, the passenger is 26.6 years old when the spaceship arrives at Altair.
natxio
1. Homework Statement
You are a passenger on a brand-new spaceship that travels at 95% of the speed of light, i.e.,
v = 0.95 × c. The spaceship is bound for the star, Altair, at a distance of 17 light years from
Earth. If the spaceship departs on your 21st birthday, at a speed of v = 0.95c, how old are you
when the spaceship arrives at Altair?
2. Homework Equations
v= d/t
3. The Attempt at a Solution
I have no idea how to do this problem, in my opinion it appears to be poorly worded, I don't know if the professor means age relative to Earth time or age relative to the traveling speed. This is my attempt to find a solution:
v=d/t v=0.95c --> 0.95c= 17lightyears/ t
t= d/ v
t= 17ly/ 0.95 c
They want the actual biological age of the passenger when he arrives at the destination. So it's his frame that we are interested in.
t= d/ v
t= 17ly/ 0.95 c
What you found is the time the trip takes according to Earth observers. That's not quite it. What would the time be according to the spaceship?
okay, I understand how to do it, so I plug what I calculated into the time dilation equation as delta t rest and calculate tmoving based on what I have given. Thank you!
Good! That works.
Another approach that will give you the same answer is to ask yourself: What is the distance traveled according to the spaceship? Then you can use T = D/V from the spaceship's frame.
the answer for tmoving is 5.6 and when you add that to the age of the passenger that is 21yrs+ 5.6 yrs= 26.6 yrs old when the ship arrives at Altair!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
