Special Relativity & No Special Inertial Frame of Reference
In summary, the special theory of relativity states that no inertial reference frame is special and it is impossible to determine whether a spaceship is moving at a certain speed or the rest of the universe is moving in the opposite direction. However, the difference in kinetic energy between these scenarios can be measured with an experiment, but it does not determine which scenario is true. Additionally, the concept of energy is not an invariant but is conserved in all frames. This is not a new concept and is also true in classical mechanics. In relativity, the assumption of the speed of light being invariant is what sets it apart from classical mechanics, where the speed of light is considered to be infinite.
manulal
As per special theory of relativity, no inertial reference frame is special! If a spaceship is moving at 100 m/s, no one can conduct an experiment to determine whether it is moving at 100 m/s or the rest of the universe is moving to the opposite direction at -100 m/s, if I understand the descriptions correctly! But what what about the huge difference in kinetic energy between these two scenarios? If the rest of the universe is moving in the opposite direction, won't it require huge energy? If an experiment can be devised to detect this difference in the energy of the whole system, can't it say if the spaceship is moving or the rest of the universe is moving?
Energy is not an invariant, meaning that it will be different in different inertial frames. However, it will be conserved in all frames.
This is not something new in relativity as it is also the case in classical mechanics. The new thing in relativity is the assumption that the speed of light* is invariant, ie, the same regardless of the observer. This turns out to be incompatible with the assumption of absolute and universal time in classical mechanics.
* Really, the assumption is the existence of an invariant finite speed. Light just happened to be the thing we already knew that traveled at this speed.
Likes russ_watters, FactChecker, SiennaTheGr8 and 2 others
Why should one value for total kinetic energy be more special than any other value?
Likes vanhees71
First, even if the universe were some rigid object there is no reason to assume it has low KE. As long as energy and momentum are conserved, there is nothing about a universe with large KE and net momentum that violates any known law.
Second, the universe is not a rigid object. If you say that it is moving at 100 m/s here then there is another location where it is stationary by parallel transport. Why shouldn’t that location be the stationary one instead of this?
There is no such thing as "moving at 100 m/s" without qualification. You have to specify what the ship is moving at 100 m/s relative to. Note that this is just as true in Newtonian mechanics as in SR.
Likes HallsofIvy and vanhees71
Exactly! What counts are energy differences measured in one frame of reference, and that's not much different in SR and Newtonian mechanics. Only the quantities transform differently when transforming from one frame of reference to another.
In Galilei-Newton spacetime you have the kinetic of a particle ##E=\vec{p}^2/(2m)##, and going from one frame of reference to another moving with speed ##\vec{v}## you have ##\vec{p}'=\vec{p}-m \vec{v}## and thus
$$E'=\frac{\vec{p}^{\prime 2}}{2m}=\frac{(\vec{p}-m \vec{v})^2}{2m},$$
while in SR ##(E/c,\vec{p})## are Minkowski-four-vector components, and ##E^2/c^2-\vec{p}^2=m^2 c^2## give the relation between ##E## and ##\vec{p}##. Note that in SR and Galilei-Newtonian physics the mass is the same quantity (which is why we use only this invariant mass ##m## in modern formulations of SR) but the relativistic energy also contains the rest energy ##E_0=m c^2##, which is not included in the kinetic energy of Galilei-Newtonian physics, but that's just a convention, because it's only an additive constant.
All that counts are energy differences, and these are interesting because of energy-conservation law (i.e., the energy-work theorem) valid for closed systems in both SR and Galilei-Newton physics, because both space-time models imply time-translation invariance and the corresponding conserved "Noether charge" of this symmetry is by definition energy.
Moderator's note: Some posts which did not add any real value to the discussion have been deleted.
There is also another way to look upon it: the speed of light is invariant in both classical mechanics and relativity. But in classical mechanics the speed of light is infinite, while in relativity it's finite.
  • Skeptical
Likes dsaun777 and PeroK
This only works if you drop "speed of light" for "invariant speed". The speed of light was known to be finite long before (1676) special relativity came along (1905). Actually, even before Newton's classical mechanics came along (1687).
In classical mechanics, light takes about eight minutes to travel from the Sun to the Earth. That was definitely understood pre-SR.
Doesn't it depend how you choose to formulate "light in the context of classical mechanics"? It's never going to be an entirely coherent concept. That light doesn't travel at infinite speed was indeed well known as far back as Rømer in 1676. But classical mechanics is the ##v \ll c## limit of relativity, which I think you can interpret as the limit as ##c## tends to infinity.
I agree with Orodruin's point that haushofer would definitely be correct if he said "invariant speed" instead of "speed of light". But whether "speed of light" is wrong seems to me to depend on whether you interpret things like Rømer's measurement as part of classical mechanics or as the first (unrecognised) crack in the edifice.
On the contrary, Rømer's measurement was in no way a crack in the theory if you see it in the context of how the theory was laid out at the time. Instead, it was reasonable to assume that light was carried by a medium (if a wave) or that its speed depended on the emitter (if particulate). Only when Maxwell’s theory of electromagnetism was laid out and searches for relative motion vs the aether failed did the cracks start to appear. There was no a priori contradiction between infinite speed being invariant and light speed being finite. That distinction comes only a posteriori after identifying the invariant speed with the speed of light, which did not happen until 1905.
Likes PeroK and Dale
Sure, but this is because "the speed of light", c, plays a double rôle: as the speed of wave propagations of the electromagnetic field, and as determining the causal structure of spacetime. I was talking about the latter ;)
Related to Special Relativity & No Special Inertial Frame of Reference
1. What is special relativity?
Special relativity is a theory developed by Albert Einstein that describes the relationship between space and time in the absence of gravity. It states that the laws of physics are the same for all observers in uniform motion, and the speed of light is constant for all observers.
2. What is a special inertial frame of reference?
A special inertial frame of reference is a coordinate system in which the laws of physics, as described by special relativity, hold true. It is a frame of reference that is not accelerating and has no net force acting on it.
3. How does special relativity affect our understanding of time and space?
Special relativity states that time and space are relative, meaning they can be perceived differently by different observers depending on their relative motion. It also introduces the concept of time dilation, where time appears to move slower for objects moving at high speeds.
4. Can special relativity be applied to everyday situations?
Yes, special relativity has been extensively tested and is used in many practical applications, such as GPS systems, particle accelerators, and nuclear reactors. However, its effects are only noticeable at very high speeds or in extreme gravitational fields.
5. What is the difference between special relativity and general relativity?
Special relativity only applies to situations where there is no acceleration or gravity, while general relativity extends the principles of special relativity to include accelerated motion and gravity. It also introduces the concept of spacetime curvature, where the presence of mass and energy can bend the fabric of space and time.
