Special Relativity: Time dilation
The discussion centers on the conceptual understanding of time dilation in special relativity as experienced by observers on a spaceship and on Earth. The Earth observer calculates the travel time for the spaceship as T1 = L/v, noting that the spaceship's clock runs slower, advancing by T0 = T1/ɣ. Conversely, the spaceship observer perceives the Earth observer's clock as ticking slower, yet concludes that the total travel time in their frame is less than that measured by the Earth observer. The conversation highlights the importance of the "relativity of simultaneity" and suggests using three clocks to analyze the situation accurately. Proper time is defined as the time measured by a single clock in a single location, emphasizing the need for clarity in comparing different frames of reference.
ntknow
Hello. This is not a concrete problem, rather conceptual question.
2. Homework Equations
3. The Attempt at a Solution [/B]
Spaceship with speed v with respect to the Earth is traveling from the Earth to say some distant star, which is distant L apart from the Earth looking by observer who is in the Earth frame. Analysis from both observers point of view:
Earth observer:
observes that spaceship travels the distance in time T1 = L/v. In addition to that, he observes that clock in the spaceship during the travel advances by T0=T1/ ɣ, i.e. less than his clock.
Spaceship observer:
by relativity he sees that the Earth observer's clock is ticking slower than his clock, however, by above argument total travel time in his frame is smaller than in the Earth frame. Additional facts are that he observes length, L, contracted and time reading difference between clock in the Earth and clock, for example, in the star.
Problem for me:
Could someone summarise / make me clear / point out flaws in the reasoning why total travel time is still smaller as observed by spaceship observer than by the Earth observer if spaceship observer during all the time then Earth gets farther from him sees the Earth observer's clock running slower?
Earth observer:
Spaceship observer:
Problem for me:
Have you covered the "relativity of simultaneity" or the "leading clocks lag" concept yet?
Yes, I am familiar with these concepts.
Can you analyse the journey from the ship's RF? Hint: you need three clocks. Two "rest" clocks: one on Earth and one at the distant star. And one clock moving with the ship.
Restating PeroK's comment: Proper time is measured by a single clock in a single place.
Only the clock on the spaceship (in the frame of) meets this requirement.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
