Special Relativity: time for light to traverse a rocket
A 35 m long rocket moving at 0.6c raises questions about the time it takes for light to travel from the bottom to the top and vice versa, as perceived by a stationary observer. The initial calculations for the time taken were incorrect due to a miscalculation of gamma and misunderstanding of light's constant speed across reference frames. The correct approach involves recognizing that light travels a distance while the rocket moves, leading to a simpler calculation of time. The revised calculations indicate that the time for light to travel from the bottom to the top is based on the corrected length of the rocket. The discussion emphasizes the importance of understanding relativity principles in these calculations.
TheLil'Turkey
A 35 m long rocket is receding at 0.6c. From the point of view of a stationary observer, how long does it take for light to travel (a) from the bottom of the rocket to the top and (b) from the top to the bottom?
t = d/v
L = L0 / gamma
a) L = 35 / gamma = 30.3 m
distance traveled by light = L + 0.6L + 0.6^2L + 0.6^3L + ... = 2.5L = 75.8 m
t = distance traveled by light/c = 2.5E-7 s
b) distance traveled by light = 1/(1 + 0.6)L = 18.9 m
t = distance traveled by light/c = 2.5E-7 s = 6.3E-8 s
Is this right? If not, please help me understand.
It is not correct. The equations you refer to in section 2 is relevant for your problem, but then you somehow calculate wrong value for gamma and get very confused about how fast light propagate showing you have missed a very special characteristic about speed of light that is fundamental to relativity.
So, can you write up an expression for gamma? And what is the speed of light in all reference frames?
Other than the calculation of gamma, which I have not checked, that looks correct.
(a) can be done without the infinite series, by noting that the light travels distance tc while the top of the rocket travels distance 0.6tc, so the difference between the two, which is the length of the rocket L, must be 0.4tc. Hence t = L/0.4 c.
Filip: Oops. I typed 0.5 instead of 0.6 in my calculator for the speed of the rocket. L = 28.0, not 30.3. I think everything else is correct.
Andrew: Thanks for showing me another way to calculate t.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
