Special relativity with particles
In summary: In this case, that means they're moving together at the same velocity. In summary, the minimum energy of the initial proton for the event ## p + \gamma \to p + \pi ## to occur is given by the conservation of energy equation, taking into account the rest masses of the particles involved. Solving the problem in the center-of-mass frame, where the resulting proton and pion are at rest, allows for the determination of the minimum energy of the initial proton.
tskuzzy
Consider the event ## p + \gamma \to p + \pi ##, where ##p## is a cosmic ray of a proton, ##\gamma## is a microwave background photon, and ##\pi## is a generated meson. What is the minimum energy of the proton for such an event to happen? Proton has a rest mass of 1 GeV/c2, π particle has a rest mass of 100 MeV/c2, and microwave background photon has an energy of 2.5*10^-4 eV.
Conservation of energy and momentum equations.
$$ E = mc^2 $$
From conservation of energy, we get the equation:
\begin{align*}
E_i &= E_f \\
E_{p_i} + E_{\gamma} &= E_{p_f} + E_{\pi} \\
E_{p_i} + 2.5 \times 10^{-4} &= \gamma_{p_f}(1 \times 10^6) + \gamma_{\pi}(1 \times 10^5)
\end{align*}
In order to minimize the energy of the initial proton, is it reasonable to simply set the gammas on the right side equal to 1 (i.e. let them be at rest)?
Nope, that would violate the conservation of momentum.
Try solving the problem in the center-of-mass frame. In that frame, the resulting proton and pion will be at rest. Then transform the results back to the lab frame.
Thanks for the speedy response!
Could you explain why the resulting proton and pion would be at rest in the COM frame? Wouldn't that imply that the two are traveling together with the same velocity? Why couldn't they fly off in different directions wrt the COM?
Because you're looking for the minimum energy. Some of the energy goes into creating the pion. Any extra ends up as the kinetic energy of the resulting particles, so to find the minimum, you want the kinetic energy to be as small as possible.
If so, then we can solve for the minimum energy of the proton using the equation:
E_{p_i} = \gamma_{p_f}(1 \times 10^6) + \gamma_{\pi}(1 \times 10^5) - 2.5 \times 10^{-4}
where ##\gamma_{p_f}## and ##\gamma_{\pi}## are the Lorentz factors for the final proton and pion, respectively. This would give us a minimum energy of approximately 1.001 GeV for the initial proton in order for the event to occur.
However, if we want to consider the actual physical processes involved in the event, we would need to take into account the momentum of the particles as well. This would require using the conservation of momentum equation:
\vec{p_i} = \vec{p_f} + \vec{p_{\gamma}} + \vec{p_{\pi}}
where ##\vec{p_i}## is the initial momentum of the proton, and ##\vec{p_f}##, ##\vec{p_{\gamma}}##, and ##\vec{p_{\pi}}## are the final momenta of the proton, photon, and pion, respectively. This would give us a more accurate minimum energy for the initial proton, taking into account the momentum of the particles and their interactions.
In conclusion, the minimum energy of the proton for the given event to occur would depend on whether we are considering only energy conservation or both energy and momentum conservation. In either case, the rest masses of the particles involved and the energy of the microwave background photon would play a significant role in determining the minimum energy of the initial proton.
Related to Special relativity with particles
What is special relativity with particles?
Special relativity with particles is a theory developed by Albert Einstein that describes the behavior of particles moving at high speeds, close to the speed of light. It is based on the principles of special relativity, which states that the laws of physics are the same for all observers in uniform motion.
How does special relativity with particles differ from classical mechanics?
Special relativity with particles differs from classical mechanics in that it takes into account the effects of high speeds and the concept of time dilation. Classical mechanics, on the other hand, assumes that time and space are absolute and that the laws of physics are the same for all observers.
What is the equation for time dilation in special relativity with particles?
The equation for time dilation in special relativity with particles is t' = t*sqrt(1 - (v^2/c^2)), where t' is the time measured by an observer in motion, t is the time measured by a stationary observer, v is the velocity of the moving particle, and c is the speed of light.
How does special relativity with particles explain the twin paradox?
The twin paradox, also known as the clock paradox, is a thought experiment that demonstrates the effects of time dilation in special relativity with particles. It involves one twin traveling at high speeds near the speed of light while the other twin remains stationary. When the traveling twin returns, they will have aged less than the stationary twin due to the effects of time dilation.
What are some real-life applications of special relativity with particles?
Special relativity with particles has many practical applications, such as in particle accelerators, GPS technology, and nuclear energy. It also helps explain phenomena such as the bending of light near massive objects and the existence of antimatter. Additionally, special relativity with particles is essential in our understanding of the universe and plays a crucial role in modern physics theories, such as quantum mechanics and general relativity.
