Specific heat capacity of gases
The discussion revolves around a homework problem involving two rigid vessels containing an ideal gas, where heat is supplied to each vessel, leading to a pressure change reflected in a manometer. Despite the heat input, the book states that the work done (ΔW) is zero because the volume for gas expansion is negligible. Participants express confusion over the assumption that the gas in both vessels remains the same despite differing heat inputs, questioning the clarity of the problem's illustration. The consensus is that the diagram should better represent the conditions affecting gas behavior. The conversation highlights the importance of clear problem statements in physics to avoid misunderstandings.
lavankohsa
Figure shows two rigid vessels A and B, each of volume 200 cm3 containing an ideal gas (Cv = 12.5 J/mol-K). The vessels are connected to a manometer tube
containing mercury. The pressure in both the vessels is 75 cm of mercury and the temperature is 300 . (b) 5.0 J
of heat is supplied to the gas in the vessel A and 10 J to the gas in the vessel B. Assuming no appreciable transfer of heat from A to B calculate the difference in the heights of mercury in the two sides of the manometer
2. Homework Equations
ΔQ=ΔW+ΔU
3. The Attempt at a Solution
I know that when we give heat to both vessel, the pressure will increase. So the mercury column will also move and there will be a difference in the height in two arms . But my book says when we give heat to vessl there of gas in both vessel will be same. So according to my book ΔW=0 for both vessel. But since mercury will move, one gas should expand and other should compress. Please help me .
They are assuming that the volume available for expansion and contraction of the gases within the manometer tube is negligible.
Chet
Likes lavankohsa
OK thanks . But they should mention it .
Yes, they should, since the figure seems to suggest that there is volume available for gas expansion and contraction in the manometer tube. But it obviously is not drawn to scale.
Chet
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
