Specific Heat Problem and boiling water
The discussion revolves around a specific heat problem involving boiling water and an aluminum pan. The user sets up the equation Q=mcΔT to calculate the final temperature after mixing 140 grams of boiling water at 100°C with an aluminum pan at 24°C. The calculations lead to a final temperature of approximately 52.319°C. Clarification is provided that this value represents the final temperature, not the temperature change. The conversation confirms the accuracy of the calculations and understanding of the concept.
clutch12
140 grams of boiling water (temperature 100° C, heat capacity 4.2 J/gram/K) are poured into an aluminum pan whose mass is 1100 grams and initial temperature 24° C (the heat capacity of aluminum is 0.9 J/gram/K).
After a short time, what is the temperature of the water?
Q=mc delta t
140g(4.2J/K/gram)(T-100) = 1100g(0.9 J/K/gram)(24-T)
588T-58800 = 23760 - 990 T
588T + 990 T = 23760 + 58800
1578 T = 82560
T= 52.319
Am I doing this right?
Looks good to me, clutch.
Alright and when I am determining the temperature am i subtracting 100-52.319 or no?
No, 52.319 is the final answer. 100-52.319 would be the change in temperature of the water.
oh ok thanks for clearing that up
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
