Speed at impact of 2 balls thrown from a building
Two balls are thrown from a 7.25 m high building, one horizontally and the other straight down, both with an initial speed of 63.5 mph. The problem seeks the difference in their speeds upon impact, with the textbook answer being -9.52 m/s. The user initially misapplied the kinematic equation, leading to confusion over negative values and incorrect calculations. After correcting the height values in the equations, the user still arrived at a speed difference of 18.86 m/s, prompting further questions about the role of horizontal speed in the calculations. The discussion emphasizes the importance of correctly applying kinematic equations to solve projectile motion problems.
KarlKarlJohn
Hi, I'm having a bit of trouble with the below practice problem from my textbook. The answer given in the back is -9.52 m/s, but there is no explanation. Thanks for any help.
Two balls are thrown off of a 7.25 m high building both at an initial speed of 63.5 mph. However, one ball is thrown horizontally and the other straight down. What is the difference in the speed of the balls when they hit the ground. This is a basic problem, so things such as air resistance don't need to be taken into account.
I believe that v_{y}^2 = v_{y0}^2 - 2g(y - y_{0}) is relevant here. However, that equation was introduced a few chapters before the chapter this problem is found in, so maybe I am supposed to use a different method involving Kinetic Energy, Work, or Power which are the subjects of the current chapter.
I converted the initial speed from mph into m/s and got 28.38 m/s. I then tried to solve for v_{y}^2 in the above noted equation for each ball. For ball 1 (thrown horizontally) I used:
v_{y}^2 = 0^2 - 2(9.81)(7.25-0) My first problem here is that this gives me a negative sign on the right side of the equation, so I can't take the square root of both sides to solve for v. I did see an example in the book though where the negative sign mysteriously disappeared, so assuming this v = \sqrt{2*9.81*7.25} = 11.93m/s
For ball 2 (thrown straight down) I solved for v with the same equation:
v_{y}^2 = 28.38^2 - 2(9.81)(7.25-0) and got v = 25.75 m/s. The difference in these values in 13.82 m/s, which is incorrect as they should differ by 9.52 m/s according to the book.
Hello KarlKarlJohn. Welcome to PF !
For ball 2:
y = 0 ,
y0 = 7.25 .
You have them reversed, so you get a negative.
For ball 2:
y = 0 ,
y0 = 7.25 .
Thanks for the help and the welcome! Switching those values makes sense and definitely helps with my issue with the negative, but I still don't seem to be getting the correct answer. I now have: v_{y}^2 = 0^2 - 2(9.81)(-7.25) \Rightarrow v = 11.92m/s
v_{y}^2 = 28.38^2 - 2(9.81)(-7.25) \Rightarrow v = 30.78 m/s
The difference in these velocities is 18.86 m/s, my book says the answer should be -9.52 m/s. Any idea what else I may be doing wrong?
What about horizontal speed?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
