Speed of an Electron in an Electric Field
The discussion revolves around calculating the final speed of an electron released from rest between two positive point charges. The problem involves using conservation of energy principles, where the initial potential energy is converted into kinetic energy as the electron moves. Relevant equations include those for electric potential from point charges and the relationship between potential energy and kinetic energy. The user is guided to sum the electric potentials from both charges and apply energy conservation to find the final speed of the electron. The key takeaway is to carefully manage the signs and values in the equations to arrive at the correct final speed.
HELLO11
Two stationary positive point charges, charge 1 of magnitude 3.25 nC and charge 2 of magnitude 1.55nC , are separated by a distance of 57.0cm . An electron is released from rest at the point midway between the two charges, and it moves along the line connecting the two charges.
find Vfinal of the electron when it is 10.0 cm from charge 1 the want the final answer in m/s
i don't get any of this my professor went to fast. can anyone help?
This looks like a conservation-of-energy problem.
The two relevant forms of energy are kinetic and electric potential.
do you know of any equations that could help me
Your book or class notes will have an equation for the electric potential (or voltage) due to a point charge.
To get the net electric potential of the two stationary charges, add up the individual potentials of each of the two charges.
To get the potential energy, multiply electric potential times the charge on the electron. Watch the +/- signs carefully.
can anyone help me
q1 = 3.25 nC, q2 = 1.55nC, d = 0.570 m. charge of electron = q, a = 0.100 m, find the final speed of the electron, v = ?
initial kinetic energy Eki = 0, potential energy Epi = Kqq1/(d/2) + Kqq2/(d/2)
final kinetic energy Ekf = mv^2/2, potential energy Epf = Kqq1/a + Kqq2/(d-a)
energy conservation:
0 + Kqq1/(d/2) + Kqq2/(d/2) = mv^2/2 + Kqq1/a + Kqq2/(d-a)
solve for v.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
