I Speed of EM & Mech Waves: Maxwell's Law Explained
Barblorrane
TL;DR Summary
Can mechanical waves be faster than electromagnetic waves?
Based on Maxwell's Law, the speed of light can be defined by:
$$c= \frac{1}{\sqrt{\epsilon_{0}\mu_{0}}}$$
Based on that, can we find a medium where a mechanical wave travels faster than a electromagnetic one? If so, how does that works?
You've written an expression for the speed of light in vacuum. Materials are held together by electromagnetic forces, so changes in the material, such as mechanical waves, propagate via the electromagnetic interaction, so at or below (usually many orders of magnitude below) that speed.
Did you mean a material with a very high refractive index so that light travels very slowly in it? I don't think you can have mechanical waves traveling faster than electromagnetic waves in such a circumstance, for much the same reason as above.
Other things such as electrons may exceed the speed of light in the medium, although they rapidly slow down, emitting Cerenkov radiation as they do.
Likes Cosmic Lollipop, Barblorrane and vanhees71
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
