- 29,404
- 21,101
In deep space, February is weightless. Is that a good start?Vanadium 50 said:<bracing for the inevitable followup> "Yeah, but if you could weigh February, what would it weigh?"
It's average mass would be approximately ##\frac{28.25}{365.25}## of the mass of one year ignoring the position-time uncertainty relationship.PeroK said:In deep space, February is weightless. Is that a good start?
This is not, to my understanding, an accurate description of the image reconstruction. Instead the fact that the two 511keV gamma photons emitted are anti-colinear (in the COM frame) allows the usual methods of CAT scan reconstruction to be used. They are likely filtered for coincidence detection but the image reconstruction is not a "time of flight" process.Steve4Physics said:For such a pair of photons, using suitable coincidence circuitry, the time-difference between photon arrivals at different detectors allows the position of the annihilation to be found. (And knowing many such positions allows image reconstruction.)
Some PET systems use time-of-flight techniques. E.g. see https://info.blockimaging.com/what-is-time-of-flight-pet-scanning.hutchphd said:This is not, to my understanding, an accurate description of the image reconstruction. Instead the fact that the two 511keV gamma photons emitted are anti-colinear (in the COM frame) allows the usual methods of CAT scan reconstruction to be used. They are likely filtered for coincidence detection but the image reconstruction is not a "time of flight" process.
Indeed you were careful with that. But the implication I took from your description was that TOF technique alone provided resolution on the scale of the images we all know. That is really not true. Improved correlation of the particular gammas does allow better signal to noise for the image reconstruction.Steve4Physics said:That’s why I said it was an 'oversimplification'
Yes. In retrospect, I should have referred to time-of-flight (TOF) PET rather than just PET.hutchphd said:Indeed you were careful with that. But the implication I took from your description was that TOF technique alone provided resolution on the scale of the images we all know. That is really not true. Improved correlation of the particular gammas does allow better signal to noise for the image reconstruction.
I thought my initial inference was reasonable from what you wrote and I wanted to disabuse others of said notion. So my reading I was incorrect (but I blame it on you)
[Edited to remove duplicated text.]Vanadium 50 said:TOF PET tells you less than you think. @hutchphd is right - it improves contrast, but it does not have the position resolution you want to measure c accurately.
Singnal formation time is 20-30 ns. Because the shape is known, one can infer the start time this to a nanosecond, maybe a little better. That gives you about a one foot position resolution. Two measurements, so you pick up a √2, so you have 8 inches. This is over about two feet, so it's a 30% measurement when all goes well.
Further, the OP specified vacuum. People have an index of refraction of about 1.3. So there's another 30% issue that needs to be understood.
Finally, such counters are timed in assuming the speed of light is c. You're going to find gammas travel at c no matter how fast they really go. The actual effect of a different speed of gammas is to worsen the resolution, not to shift anything in a visible way. If instead of the theoretical 8 inches you might see 9 or ten.
I worked in a lab that measured the distance Earth to moon with laser pulses, only few photons returned due to the distance, but the assumption that they move at the speed of light was never questioned and results were coherent with the expected movement of the moon, that is of course in the range of accuracy of a few mm with respect to 400000 km.LarryS said:TL;DR Summary: Does speed of individual photons in a vacuum vary?
Is there experimental evidence that confirms that the speed of individual photons in a vacuum never varies, even slightly?
Thanks in advance.
