Speed of light inside a black hole
In summary, the conversation discusses the concept of light being slowed down when traveling through a medium with a higher density, such as inside a black hole. The participants also explore the idea of a black hole having a density similar to that of water, and how this relates to the formation of the black hole's horizon. They also discuss the role of matter continuously falling into a black hole, and how it affects the density and ability of light to escape. Ultimately, the participants conclude that the density of a black hole is not a significant factor in the inability of light to escape, as the majority of the mass is concentrated at the center.
Gerinski
323
We know that light's speed gets slowed down when traveling through a medium, and the more dense the medium the slower light can travel (of course c remains constant, but it takes longer to travel due to the continuous scatterings, absorbtions and re-emissions).
Inside a black hole, just below the Schwarzschild's radius, matter density should be high enough as to also slow down light? If so, besides the usual description that it's gravity's spacetime curvature which traps any light emitted from within the Schwarzschild radius preventing it from escaping, could the slowing down due to matter density be also a contributing factor in light being unable to escape? so in fact the hole could become black even with a mass a bit lower than that required for the spacetime curvature effect alone?
Of course I don't know if the interior of the black hole can be considered 'transparent' or 'opaque', but this is linked to some comment I read that the density at the Schwartzschild radius of some black holes can be similar to that of water:
https://www.physicsforums.com/threads/density-of-supermassive-black-holes.483191/
Astronomy news on Phys.org
The "density" of a BH is a mathematical fiction without much physical meaning. It's just the mass divided by the volume surrounded by the Event Horizon, but the mass is all in the center so the density just inside the EH is essentially zero and so consequently your concept that this "density" would contribute anything to slowing anything down does not make sense.
Lots of ideas flying around here, not always consistently.
Inside a black hole there is this interesting condition that all time-like and all null-like geodesics point inward. This means that inside the horizon all matter and all light is getting closer to the central singularity. And, as a homework assignment in my fourth year undergrad shows, the proper time matter experiences before it gets to the singularity is finite. This is the property that makes the black hole black.
So, absent matter continuously falling into a black hole, the idea you describe of dense matter just inside the horizon does not apply. Light that goes inside the horizon keeps going to the centre.
The nature of a very dense object that is not inside its horizon is very different. As long as the object is outside its horizon, then light can escape. Mass can escape. It may do it very slowly, very inefficiently, require a lot of kinetic energy to do it, etc. But in principle, it can escape.
The idea of a black hole with the density of water, or even less, goes like so. The mass required to be inside a given radius to produce a black hole is proportional to that radius. Twice the mass will disappear inside a radius twice as big. But the volume inside that radius is proportional to the cube of the radius. So the volume inside twice the radius is eight times as much. This means that, with uniform density, a larger mass disappears at a larger radius proportional to the radius. But with a volume proportional to the cube of the radius. And so a density proportional to one over the cube of the radius. So twice the mass will have one eighth the density when it disappears behind its own horizon. So with a mass in the range of a galaxy, it would disappear behind its horizon with a density about that of air.
The reason this last is important is because it tells us that a gravitational horizon could form in a range of densities that do not involve any unusual state of matter. So the concept of a black hole, at least the horizon part, is not affected by any potential exotic behaviour of matter at high densities. Something odd may happen at the singularity. Indeed, one would expect that something unusual might well happen before infinite density was achieved. But the horizon can happen at very mundane density.
Thanks. So first, you are both saying that unless new matter is falling into the hole, all the volume from the EH to the center is empty vacuum of heavily distorted spacetime, all the mass is at the center (let's not bother with the singularity itself). If so it's fine, but then the question itself becomes trivial, as no light can be emitted from within the hole if there is no matter there. Frequent popular pictures depict the fact that light can not escape by picturing some photon(s) being emitted close below the horizon and showing that their path bends inwards. The truth though according to you is that they are black not just because light can not escape, but because there is no light to escape, there's no matter inside which could radiate a photon, right? (besides the matter at the center, let's forget about that for simplicity).
Secondly, black holes do frequently have large accretion disks of infalling matter (well, if only because these are the ones we can detect most easily). So in these, around the disc rotation plane there is matter continuously falling in, so there must be certainly a 'density' in the region below the EH and beyond towards the center. All that matter must fall with a certain velocity, it does not suddenly disappear at the EH and reappear at the center. And that infalling matter may still radiate photons on its way from the EH towards the center. So in this case, those photons might be slowed down by the matter density, just as I was asking in the OP. Well at least this seems intuitively reasonable.
I understand that the geodesics point towards the center because of gravitational warping, I only asked whether it could be the case that even at a point where the geodesic still escapes the hole by a small fraction, in practice light from that point can not escape because it gets slowed down by the matter density in that region and ends up going also to the center. No more no less. BTW, if what I said makes sense, the fact that in black holes with infalling matter from an accretion disk, in the 'equator' plane there is matter all the way from EH down to the center, while in the 'polar' plane all the distance between EH and center is empty vacuum of distorted spacetime, shouldn't it mean that rotating black holes with infalling matter are not precisely spherical but slightly flattened as the Earth is?
I wouldn't say that. As far as I understand, matter takes some amount of time to fall from the EH to the singularity, which means that there is actually matter inside the EH that can emit light.
Geodesics cannot escape the black hole at all. A geodesic is a one-dimensional line with no width, so it cannot 'escape by a small fraction'. Once the geodesic is inside the EH, it stays there.
Related to Speed of light inside a black hole
What is the speed of light inside a black hole?
The speed of light inside a black hole is believed to be the same as the speed of light in a vacuum, which is approximately 299,792,458 meters per second. This is due to the extreme gravitational pull of a black hole, which warps space and time and does not allow any objects, including light, to escape.
Can anything travel faster than the speed of light inside a black hole?
No, according to Einstein's theory of relativity, the speed of light is the maximum speed at which any object can travel through space. This applies even within the intense gravitational force of a black hole.
How does the speed of light affect the formation of black holes?
The speed of light plays a crucial role in the formation of black holes. When a massive star runs out of fuel and collapses in on itself, the intense gravitational pull causes the speed of light to decrease, eventually reaching zero at the center of the black hole. This creates a singularity, a point of infinite density, where the laws of physics, including the speed of light, break down.
Does the speed of light change as you get closer to the event horizon of a black hole?
No, the speed of light remains constant as you approach the event horizon of a black hole. However, the intense gravitational pull causes space and time to become highly distorted, making it appear as though the speed of light is changing. This is known as gravitational time dilation.
How does the speed of light inside a black hole affect our understanding of the universe?
The speed of light inside a black hole challenges our current understanding of the universe and the laws of physics. It also raises questions about the nature of time and space, and the possibility of traveling through black holes to other parts of the universe or even different dimensions. Further research and exploration of black holes may provide new insights into these mysteries.
  • Astronomy and Astrophysics
