I Speed of Light Paradox: Neutron Star Rotation Rate
jflies
TL;DR Summary
If a neutron star spins fast enough, doesn't it imply that either (1) surface speeds greater than the speed of light are possible or (2) angular momentum is not conserved?
Sorry if this is a stupid question but I couldn't find an answer anywhere. According to 2 scientific papers, the neutron star PSR J1748-2446ad has a rotation rate of 716Hz, which equates to a linear surface speed of 0.24c. What if this star was originally rotating, let's say, 5 times (or more) faster before it collapsed. That would imply that it's surface speed would reach 1.2c. How could the conservation of momentum hold true unless speeds greater than 1c are allowed?
Angular momentum does not scale linearly with angular velocity. It approaches infinity as the linear speed approaches ##c##. So any initial angular momentum can be accommodated in the collapsed state without exceeding the speed of light.
Note that neutron stars are extremely complicated objects and you really need to think about their full stress-energy tensor.
Likes Dale and vanhees71
Ok thanks for the quick response (and not making fun of my lack of knowledge)!
jflies said:
Summary: If a neutron star spins fast enough, doesn't it imply that either (1) surface speeds greater than the speed of light are possible or (2) angular momentum is not conserved?
Momentum does not increase linearly with speed. Linear momentum, ##p##, for example is given by:
##p = \frac{mv}{\sqrt{1-v^2/c^2}}##
You can see from this formula that any momentum can be obtained (no matter how large) with a speed of less than ##c##.
When ##v## is small compared to ##c##, then you get the classical, Newtonian approximation:
##p \approx mv##
But that only holds for speeds much less than ##c##.
Likes vanhees71
##p \approx mv##
Yup, I was only considering the Newtonian approximation. Thanks for the clarification.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
