Speed of two protons (I think an easy question)
  • Thread starter Thread starter iamkristing
    Protons Speed
The discussion revolves around calculating the top speed of two protons released from rest at a distance of 1.500 nm apart. The relevant equations include F=ma and the kinetic energy formula involving electrostatic force. The user correctly calculated the speed using the mass and charge of the protons, arriving at a speed of approximately 9.59 x 10^3 m/s. A minor typo regarding the distance was noted, but the overall calculation process was confirmed as correct. The discussion concludes with validation of the user's approach to the problem.
iamkristing
[SOLVED] speed of two protons (I think an easy question)
If you release two protons from rest 1.500nm apart, calculate the top speed, relative to you, that either proton will achieve.
F=ma
ke^2/r=mv^2 where k=9.0e9 Nm^2/C^2 and e is the charge
mass proton = 1.67e-27
charge proton = 1.60e-19
So just plug in and solve for v=
v= [(9e9)((1.6e-19)^2/(1.5e-19))/1.67e-27]^1/2
v=9.59e3 m/s
I just wanted to make sure the process I used for this problem was correct...
Thanks!
Looks good.
Just one typo ( r = 1.5e-19 ? ), but you did use the right number in the calculation.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
