Speed of Voyager 2 after slingshot encounter?
Voyager 2 utilized a slingshot maneuver to approach Saturn at a velocity of 12 km/s relative to the Sun, while Saturn's orbital speed is 13 km/s. The discussion focuses on determining Voyager 2's speed after the slingshot encounter and the relevance of various factors, including the point of closest approach and the trajectory of Voyager 2. It is clarified that the distance between Earth and Saturn does not significantly impact the calculations, as Earth's gravitational influence is negligible at such distances. The key takeaway is that Voyager 2's speed post-encounter can vary based on its trajectory and proximity to Saturn. Understanding these dynamics is essential for calculating the spacecraft's new velocity.
atomant
Voyager 2 used a slingshot maneuver to approach Saturn and then move off in the opposite direction.Voyager 2 approached Saturn with a velocity of 12 Kms^-1. (relative to the sun). The orbital speed of Saturn is 13 Kms&-1. The question is what was Voyager 2's speed after the slingshot encounter? (and relative to what?).
So can Voayger 2's speed after the slingshot encounter be calculated using the distance between the Earth and saturn?
You need more information to solve the problem. Also, I don't see how the distance between Earth and Saturn would matter.
-Dan
So what exactly am i missing?. G of the 2 planets?
Depending on the level of the problem you could be missing a number of things. The point of closest approach to Saturn, the trajectory of the Voyager in general, the change in Saturn's orbital momentum, etc. Basically the Voyager can come out with just about any momentum (within certain limits) depending on how close it gets to Saturn.
The reason I said that the Earth-Saturn distance doesn't matter is that the Earth is sufficiently far away as to essentially not act on the Voyager gravitationally. The incoming trajectory of the Voyager is the most important piece of information. At these ranges only Saturn's gravity field is important.
-Dan
I get it. Thanks for the help.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
