Speed of wave from wave equation.
The discussion revolves around determining the speed of a traveling pulse described by the equation f(x,t)=A{ e }^{ \frac { 2abxt-{ a }^{ 2 }{ x }^{ 2 }-{ b }^{ 2 }{ t }^{ 2 } }{ { c }^{ 2 } } }. Participants explore converting this equation into a standard wave form to identify the wave number (k) and angular frequency (ω). The consensus is that the speed of the pulse can be expressed as v = b/a, which aligns with the form f(x-vt). The conversation highlights that while sinusoidal waves are commonly studied, non-sinusoidal waves also exhibit propagation velocity independent of trigonometric properties. Ultimately, the derived speed of the pulse is confirmed to be v = b/a.
back2square1
A traveling pulse is given by f(x,t)=A{ e }^{ \frac { 2abxt-{ a }^{ 2 }{ x }^{ 2 }-{ b }^{ 2 }{ t }^{ 2 } }{ { c }^{ 2 } } } where A, a, b, c are positive constants of appropriate dimentions. The speed of pulse is:
a) \frac { b }{ a }
b) \frac { 2b }{ a }
c) \frac { cb }{ a }
d) \frac { b }{ 2a }
\tilde { f } (x,t)=\tilde { A } { e }^{ i(kx-\omega t) } and
\omega=kv
\tilde { f } is complex wave function.
\tilde { A } is complex amplitude.
k is the wave number.
\omega is angular frequency.
v is the velocity of pulse.
The strategy was reduce the equation into the standard wave equation and see which part corresponds with \omega and k. Once we find the expression for \omega and k, its not very difficult to find the velocity using the 2nd equation.
The equation doesn't contain i. But reducing the equation, we get something like this,
f(x,t)={ e }^{ { (i\frac { ax-bt }{ c } ) }^{ 2 } }. The only problem is how to get rid of the square? Using logarithms wasn't helpful.
a) \frac { b }{ a }
Your wave function is a function of position and time. What is speed, with respect to these two variables? :-p
This equation is for a "sinusoidal" or "harmonic" wave that extends from -∞ to ∞.
More generally, any well-behaved function f(x,t) of the form f(x-vt) would represent a wave traveling in the positive x direction with speed v. (You do not need to have ##i## in the expression).
Can you express your function in the form f(x-vt)?
TSny said:
You do not need to have ##i## in the expression.
I don't understand. ##{ e }^{ i\theta }=cos(\theta )+i sin(\theta )## is the reason why we can write sinusoidal wave in Euler's from. Without ##i##, how can we say its a sinusoidal wave?
Expressing it as a function of ##x-vt##, it looks like this: ##f(x-vt)=A{ e }^{ -\frac { a }{ c } { (x-\frac { b }{ a } t) }^{ 2 } }##, which indicates that velocity of pulse is ##v=\frac { b }{ a }##. So, are you trying to say that is the answer?
Note that you are talking about "sinusoidal" waves. Non-sinusoidal waves do not have to be in that form, naturally. Yet they must still have a propagation velocity, so that can't depend on some property of trigonometric functions.
The only reason why we study sinusoidal waves extensively is because they are the simplest solutions of the wave equation and because practically any wave can be represented as an (infinite) sum of sinusoidal waves.
Yes, that's essentially right. I think the factor of a/c should also be squared, but that doesn't change the answer.
Likes 1 person
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
