Speed of wind and speed with respect to wind
  • Thread starter Thread starter Astraithious
    Speed Wind
The discussion revolves around calculating the wind speed and the speed of the aircraft with respect to the wind. The pilot points the aircraft due west while the wind blows towards NNE, resulting in a ground speed of 64 m/s at 25° N of W. The participant initially calculated the wind speed as 85 m/s and the aircraft's speed relative to the wind as 38 m/s but expressed confusion about the correctness of these values. Clarifications were provided regarding the angle of NNE, which is actually 67.5 degrees N of E, and the relationship between the calculated speeds, suggesting that the wind speed should be the lower value. The discussion emphasizes the importance of understanding vector components and the correct definitions of the terms used.
Astraithious
A pilot points an aircraft due west, while the wind blows towards the NNE (45 degrees north of east). The resultant velocity of the aircraft over the ground is 64 m/s, 25° N of W .
(a) At what speed does the wind blow, and
(b) what is the speed of the plane with respect to the wind? (7 marks)
a) Vpw = 85 m/s
b) Vwg = 38 m/s[/B]
sine/cosine law
i ended up with 85 for speed with respect for wind, and 38 for wind speed.
I just can't wrap my head around why they are swapped. Any help would be appreciated
What do the subscripts on v mean in your notation? And have you learned how to use vectors in i,j,k form?
Sorry for the late reply and no i have't yet. first is vpw = speed of wind and vwg is velocity of the plane with respect to the wind
I don't think the definitions you have given are correct.
a) Vpw = 85 m/s
b) Vwg = 38 m/s[/B]
sine/cosine law
NNE is not 45 degrees N of E. That's NE. NNE is 67.5 degrees N of E.
Are you saying the two answers you quote are swapped around in relation to the official answers? If ao, the official answers must be wrong. The aircraft's course is not greatly affected by the wind, so the wind speed must be the lower of the two.
If you still have reason to think your answers are wrong, please post your working.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
