Speed, Velocity and Acceleration Problems with Two Objects Involved
In summary: Sorry. but am i right? when i calculated the speed of the 2nd runner then multiplied their difference of time [which is 2 seconds] with it? i'd actually get the distance of the two? :DNo, I don't believe you're right. When the 1st runner finishes the race the 2nd runner has not yet finished. He still has some distance to go at the speed you calculated earlier. So the distance between the runners is not the difference of the distances they run.In summary, the first problem involves finding the time and distance traveled by a person driving at a constant speed of 89.5 km
CallMeMarvin
1. A person takes a trip, driving with a constant speed of 89.5 km/h, except for a 22 min rest stop. If the person's average speed is 77.8 km/h, how much time is spent on the trip and how far does the person travel?
2. Two sprinters finish with times of 3:53.58 and 3:55.66. Assuming that both run 1609 m at constant velocity,, what distance separates them at the end of the race?
S = d/t?
I don't know but I sort of feel they're the ones involve here. PLease help me, cause I don't have any idea with this, and its our exam tomorrow
1. I did a tabular there.
1st Part has only speed given.
2nd Part has only the time. [rest for a moment]
3rd Part has the total speed.
but got stuck when solving it, cause I can't find the distance and time of the 1st velocity. I tried diving the time of the 2nd to the speed of the first but it doesn't seem to work out.
2. For here so far
i just converted the two times into seconds and then I each multiplied them to their designated speeds but got stuck in what i really need to find.
Sorry :( i really need your help, can you please please please help me :(((
i'm sorry if this is all i can give for an attempt. :'(
S = d/t?
Assign a variable name, say T, to the unknown total time for the trip. Can you write an expression for the total distance traveled if the driving speed is V and the rest stop time Tr?
(Hint: If the total time is T and the rest time is Tr, how much time was spent at speed V?)
2. For here so far
Given the track length and the finish time of the second runner, what was his speed?
How much time separated the second runner's finish from the first runner's finish?
1st Question..
so this should be like S = VTr ?
2nd Question..
2nd Runner's speed is 6.85m/s
1st Runner's speed is 6.91m/s
2nd Runner's time is 235 seconds
1st Runner's time is 233 seconds
so tell me if i follow.
then i should find the difference of the two times so that's 2 seconds and then what?
should i multiply 2 seconds to the 2nd runner speed then if so, I obtained 13.7m. and same goes with the 1st runner, which I have obtained a distance of 13.8m.
Should I then subtract them? so the actual distance of the 1st to the Runner is .1m ?
CallMeMarvin said:
1st Question..
Well, not quite. He's not moving at all while he's resting, so he travels no distance during time Tr. He DOES move during the rest of the time... So if T is the total time and Tr is the rest time, what is the time during which he is moving?
2nd Question..
Stop right there. At the instant the first runner finishes the second runner still has 2 seconds to run according to your calculations. He does so at the speed you calculated for him. So the distance you calculated IS the distance between the runners.
for the 1st question.
i actually don't get what you mean there :( .. sorry.
is it
Tm [m for moving] = T - Tr
where in the V's time is Tm?
cause as of now, we cannot obtain the total time and the V's time right?
for the 2nd question.
presenting the mathematical representation:
S2nd Runner = dof runners / twhere it is their difference between the time they ran the whole lap
is it
As of now you can write the total time that the person is in motion as: T - Tr, where T is still unknown. Write the total distance he drives given that his speed is V=89.5 km/h over the time (T - Tr). Then consider what the definition of average speed is (and since you're given a value for the average speed you should then be in a position to solve for the total time, T).
When the first runner is at the finish line the second runner still has approximately 2 seconds of running to do at his constant speed. You can work out the distance from the time and speed. NOTE: be sure to calculate the time difference accurately. Hundredths of a second are important here.
Related to Speed, Velocity and Acceleration Problems with Two Objects Involved
1. What is the difference between speed and velocity?
While both speed and velocity measure how fast an object is moving, velocity also takes into account the direction of motion. Speed is a scalar quantity, meaning it only has a magnitude, while velocity is a vector quantity, meaning it has both magnitude and direction.
2. How do you calculate average speed?
Average speed is calculated by dividing the total distance traveled by the total time taken. This formula can be written as:
Average Speed = Total Distance / Total Time
3. How does acceleration affect an object's motion?
Acceleration is the rate at which an object changes its velocity. If an object experiences acceleration, it will either speed up, slow down, or change direction. The magnitude of acceleration can be determined by dividing the change in velocity by the change in time.
4. Can two objects have the same speed but different velocities?
Yes, two objects can have the same speed but different velocities if they are moving in different directions. For example, if two cars are both traveling at a speed of 50 mph, but one is heading north and the other is heading south, their velocities are different.
5. How do you solve problems involving two objects with different speeds and directions?
To solve problems involving two objects moving at different speeds and directions, you can use the principles of relative motion. This means considering each object's motion as if the other object is stationary. Then, you can use the equations for speed, velocity, and acceleration to solve for unknown variables.
20K
