- #36
yuiop
- 3,962
- 20
RandallB said:When you used both “Bob's point of view” and “Alice's point of view” as reliable to judge distant event synchronizations (causality) you did not just define a preferred frame, you used two of them!
It is not a case of defining a preferred frame. That is sort of the whole point of relativity. there is no preferred frame. I used two frames to describe the situation from different view points and I could have used an infinite number of different frames. Being able to describe a situation from any number of arbitary reference frames is the same as having no preferred frame.
RandallB said:When
As I said before; You need to be much more detailed:
Care to explain exactly when and where in the Alice's frame Bob was when the 2c FTL message was sent and recieved?
And exactly where and when was Alice in Bob’s frame when she sent it and when he received it to return a #C FTL reply?
How fast are Alice and Bob moving wrt each other and is that towards each other or apart?
I mantioned in the first post with the diagram that Bob and Alice are moving away from each other at 0.9c. The rest of your questions are answered in this updated diagram.
http://img383.imageshack.us/img383/4903/superluminal2zn9.th.gif
Note that observers in Alice's frame do not agree with a lot of things that observers in Bob's frame measure and vice versa. That is the failure of simultaneity of space-like events.
RandallB said:Only “c” appears to be the same in all frames; how fast is the c2 signal measured in Bob's frame and how fast is the 3c signal when measured in Alice’s frame?
In Bob's frame Alice is moving at -0.9c (right to left) and by the velocity addition formula her query signal of +2c (left to right) as measured in her frame, is 1.235c (left to right) according to observers in Bob's frame.
Note that the sign of the velocity does not tell you whether the signal is going forward or backwards in time but only tells you whether it is going left or right.
In Alice's frame, Bob is moving at +0.9c (left to right) and by the velocity addition formula his reply signal of -3c (right to left) as measured in his frame, is -1.375c (right to left) according to observers in Alice's frame.
Note once again the negative signal velocity in itself does not imply backwards in time but only give direction (right to left).
To determine the order of events, the time intervals have to be calculated using the Lorentz transformations as demonstrated in https://www.physicsforums.com/showpost.php?p=1947893&postcount=17".
RandallB said:Exactly what established the foreword and backward time changes you are plotting if not some frames of reference?
The Lorentz transformations establish the forword and backward time changes.
RandallB said:What do you change that would have caused Bob’s replies to have come further in the future than of all Alice’s questions and responses to his replies.
If Bob is at rest with respect to Alice or if Bob is going towards rather than away from Alice, then Alice would receive the replies after the queries (normal time order) even with superluminal signal speeds.
However, I don't think that is exactly what you are asking and it hard to interpret what you mean. Could you rephrase it using normal syntax?
Also, "Bob's replies" is a vague. There are two events involved in a reply, namely, Bob sending a reply and Alice receiving Bob's reply. If you mean that Bob sending a reply is in the future of Alice receiving the reply then that is entirely subjective. There is no way to determine if one event is in the future or past of another event in any absolute sense, if those two events are space-like separated.
