Erwin Derek
Lenz's law shows that dropping a magnet through an aluminum pole will cause an induced current that slows down its fall drastically.
I found a website that talks about this a little: https://www.lhup.edu/~dsimanek/TTT-slowfall/slowfall.htm
It has the following question:
I don't see any reason why the sphere would rotate. I think the net force exerted by all the induced currents should just point directly up regardless of what orientation the magnet is dropped. Can anyone explain if the sphere would rotate to have its poles vertical or horizontal, and why would it do this?
I am guessing it may have to do with the resistivity of aluminum or something...
Obtain such a spherical magnet that is slightly smaller than the inside diameter of the tube. The sphere will fall slowly down the tube just as the cylinder did. Mark the magnet "poles" with small colored stickers. Now watch the sphere from above as it falls down the tube. Does the sphere always rotate and re-orient so that one of the poles is up, and the other down? Or does it re-orient with the magnetic axis horizontal? Why?
