Spherical star in a hydrostatic equilibrium
The discussion focuses on deriving the equation of motion for a perturbation in a spherical star under hydrostatic equilibrium. Key points include the distinction between "d" for location changes and "delta" for perturbations, emphasizing the need to apply momentum equations to delta variables. One participant expresses confusion over the complexity of their derivation, suggesting that a simpler approach may exist. Another contributor critiques the relationship between density and mass in the derivation, advocating for a differential approach rather than a mean density perspective. The conversation highlights the challenges in applying variations and linearizing equations in astrophysical contexts.
ted1986
Hello again,
I've got a question about a star in a hydrostatic equilibrium.
How do I derive an equation of motion for a pertubation in the full momentum equation? I'm attaching my solution (my_solution.jpg) , but I'm not quite sure about it.
The full exercise is attached as astro_problem.jpg.
Thank you.
Astronomy news on Phys.org
It's not that simple, the meaning of "d" and "delta" are different. The meaning of "d" is "a change as you change location", but the meaning of "delta" is "perturbed from the original equation." So before you substitute and delta expressions, you first have to find the momentum equation that applies to the delta variables. When you're all done, you'll still have d/dr kinds of things, but they will apply to the delta variables, not the P and rho by themselves.
I think I did this once. I even thought it was my idea. Don't use their hints, see attachment. The "del" works like del f = f' del r.
OK, I tried to solve the exercise as you said (P=K*rho^\gamma), but the equaion I've got seems to be to complicated... (my derivation is attached - star_my_sol2.jpg)
Perhaps the derivation needed to solve it is less complicated?
Thank you.
Sorry, but that's way off because the way you related density and mass. Your equation would only work for mean density, were M the total mass. Their relationship is instead differential.
The knack here is to apply the variation ( perturb ) and then factor out ( linearize ) the del-r out. Since the variation is arbitrary, the parenthetical stuff must equal zero ( the derived equation ).
I don't get the hints they gave.
Thank you for your efforts :)
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
