I Spin expectation value for one particle vs actual measurement
Ahmed1029
When the expectation value of spin in the z direction for one particle is zero and I make measurements for an even number of particles in the same state, do I get exactly half to be spin up and half to be spin down along the z direction? More generally, what does spin expectation value for one particle say about measurement of many particles in the same state?
No more than if you toss an even number of coins you get half heads and half tails.
Expectation value is a statistical concept. One way to look at a probability is as the limit of relative frequency. In that sense, the average value of a sample tends to the expectation value as the size of the sample increases without bound.
If these concepts are unfamiliar to you, you need a course in basic probability theory.
Likes dextercioby, vanhees71, topsquark and 2 others
Not exactly, but I kind of get the idea as I was exposed to the notion of a probability ensemble before. My guess is that the expectation value tells me that if I have infinite identical systems and measure the average value of Z spin after measurement it will be the same as the expectation value. Am I right?
If you are dealing with a two state system, such as (potential free) spin 1/2 system, then yes. But if you have more than two states then this may not be true. The ensemble average of a three state system may not be the average of the individual states. For example, if we have an electron in a hydrogen atom the ensemble average of the electron's energy will not simply be the average of the energies of each state. The electron has a greater probability of being in the n = 1 state so the ensemble average will be reasonably close to the n = 1 energy.
-Dan
More or less. Although "limit of relative frequency" is more mathematically well-defined than "an infinite number of systems".
Likes vanhees71, topsquark and Ahmed1029
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
