Splitting Comet Momentum Problem Solutions
  • Thread starter Thread starter kariibex
    Momentum
A comet with a mass of 6000 kg traveling at 30,000 m/s splits into two pieces, with one piece being five times the mass of the other. The masses are calculated to be 1000 kg and 5000 kg, with the smaller piece moving at an angle of 20° above the horizontal and the larger piece at 20° below. The momentum before the split is determined to be 1.8 x 10^8 kg m/s. Two equations are set up to solve for the velocities of the pieces, considering their respective momentum components in the x and y directions. The discussion emphasizes the use of substitution for solving the independent variables in the equations.
kariibex
A comet of mass 6000 kg traveling at 30 000 m/s splits into two pieces that move apart with velocities that make equal angles of 20° relative to the original trajectory. If one piece is found to be 5 times the mass of the other...calculate the mass of each piece, find the impulse of the system, and calculate the velocities of the two pieces.
P = mv
P total before = P total after
Impulse = ΔP
Mass 1 = 1000 kg and Mass 2 = 5000kg
i assumed that mass one traveled 20° above the horizontal, while mass two traveled 20° below the horizontal.
So;
P before = mv = (6000kg)(30 000 m/s) = 1.8 x 10^8 kg m/s [+x]
P1 after = m1v1 = 1000v1 kg m/s [+x 20° +y]
P1 after X = 1000(v1) kg m/s cos20° = 939.69(v1) [+x]
P1 after Y = 1000(v1) kg m/s sin20° = 342.02(v1) [+y]
P2 after = m2v2 = 5000v2 kg m/s [+x 20° -y]
P2 after x = 5000(v2)cos20° = 4698.46(v2) [+x]
P2 after y = 5000(v2)sin20° = 1710(v2) [-y]
Vector Equations
x: 1.8 x 10^8 kg m/s = 939.69(v1) + 4698.46(v2)
y: 0 = 342.02(v1) - 1710(v2)
I'm not sure how to solve for the velocities at this point, any help is appreciated.
Thank you!
Two equations, two unknowns...
I'm allowed to use substitution even though they're in different axis?
Yup. V1 and V2 are independent variables that appear in both equations and must have the same values in each!
Ahh! Thank you so much :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
