Why are spokes used in bicycle wheels?
In summary, spokes on a bicycle wheel are there to increase the moment of inertia, which allows for greater acceleration and easier recovery from disturbances in speed.
takando12
123
Poster has been reminded to post homework questions in the Homework Help forums
We were asked a question about why there are spokes in a a bicycle wheel. Our teacher hinted that It was related to moment of inertia. Ok so this kind of a wheel will have a higher moment of inertia than say, a solid disk-like wheel. But how is that useful?
No, the solid disk will have a higher moment of inertia, because it will be heavier. But the spoked wheel will have a higher ratio of moment of inertia to mass.
On a bike it's good for that ratio to be high because mass makes the bike harder to ride up hills (bad) whereas moment of inertia helps keep the bike upright by increasing the angular momentum of the wheels at a given speed (good).
Mass doesn't matter much when there are no hills, which is why riders use solid rear wheels in time trials when there are no major hills, and on a velodrome they use solid front wheels as well.
Other reasons to avoid solid wheels are that they are very expensive and they make you vulnerable to being blown over by the wind - especially on the front wheel.
I always thought a bicycle wheel had spokes to keep the axle from dragging on the ground. It's much easier to pedal the bike when the wheels turn. :wink:
Likes billy_joule and DEvens
Bicycle wheels have spokes because they are lighter. There are also some competition bicycle wheels similar to motorcycle wheels (see attachment), which allows for tubeless tires. The reason for "solid" wheels (they're just covered, not actually solid disks), is reduced aerodynamic drag, but a bit more weight. In most of the other competitive events, bicycle racers are drafting in a pack, until near the end, and then light weight is signficant for the final sprint.
Well I suppose I will get a zero if I write that answer. :smile:. She was pretty insistent on the moment of inertia.
OK, moment of inertia. Although the ratio of moment of inertial versus total mass is less for a solid disk than a spoked wheel, the total moment of inertial of a spoked wheel will be less than that one made from solid disk due to the lighter weight. The lower overall moment of inertia allows for greater acceleration, allowing a bicyclist to recover sooner from disturbances in speed.
andrewkirk said:
moment of inertia helps keep the bike upright by increasing the angular momentum of the wheels at a given speed.
Self-stability of a bike is due to steering geometry, like trail other physical configuration that steers the front wheel inwards in response to lean angle that tends to keep a bike vertically oriented (although the direction will change due to disturbances). Gyroscopic precession along the front wheel's steering axis is a reaction to roll torque, and in general, opposes / dampens the corrective steering reaction related to steering geometry.
Unfortunately, I have to disagree with your teacher here. Bicycle wheels are spoked because spokes are an inexpensive and simple way to obtain a very high strength to weight ratio. To elaborate:
A solid wheel or a wheel with a few large spokes (like this) will largely support the weight of the rider through compression of the structure between the wheel axle and the road. The problem with supporting the weight through compression is that only a very small cross section is needed to support the weight, but because of the length from the hub to the rim, a small cross section would be prone to buckling. Therefore, a much larger (and therefore heavier and more expensive) structure is needed just because the weight is supported in compression.
Spokes elegantly solve this by making the rim a major part of the load bearing structure. Spokes are under tension when they are installed, and are not designed to take any real load at all in compression (you could probably easily bend one by trying to compress it by hand). However, they are very, very good in tension. A spoked wheel is supported by the spokes between the hub and the top of the rim - the hub is basically hanging from the top of the rim, and then the rim and tire transfer that load down to the ground. Because a structure in tension cannot buckle, you are now limited by the tensile strength of the steel spokes itself, which is incredibly high. This allows for a lighter, cheaper wheel. Inertia has little to do with it, other than that the spokes allow for the lowest weight (and lowest inertia) wheel designs. for a given material.
Likes billy_joule and rcgldr
FAQ: Why are spokes used in bicycle wheels?
1. What is the purpose of spokes in a bicycle wheel?
The primary purpose of spokes in a bicycle wheel is to support the weight of the rider and the bike, while keeping the wheel round and balanced. They also help distribute the force of pedaling and absorb shock from bumps in the road.
2. How many spokes are typically found in a bicycle wheel?
The number of spokes in a bicycle wheel can vary, but the most common number is 32. More spokes can provide greater stability and weight distribution, while fewer spokes can reduce the weight of the wheel.
3. What materials are spokes made of?
The most common material used for spokes is stainless steel, as it is strong, durable, and resistant to corrosion. However, spokes can also be made of other materials such as aluminum, titanium, or carbon fiber.
4. Can spokes be adjusted or replaced?
Yes, spokes can be adjusted to fine-tune the tension and balance of the wheel. However, if a spoke is damaged or broken, it will need to be replaced. This is typically done by a professional bike mechanic.
5. Do different types of spokes affect the performance of a bicycle wheel?
Yes, the type of spoke used can affect the weight, strength, and flexibility of the wheel. For example, bladed spokes are more aerodynamic but may not be as strong as round spokes. It is important to choose the right type of spoke for your riding style and needs.
