Sprag clutch with disengagement
  • Thread starter Thread starter Stormer
    Spring
Sprag clutches typically engage through spring tension, preventing disengagement unless unloaded. The discussion explores the challenge of creating a sprag clutch that can disengage when not under load, particularly for a DIY ebike to allow free backward movement. Suggestions include using a solenoid to release sprag tension or employing two sprag clutches in series, though both options face space and complexity issues. The consensus is that a manually operated clutch or disabling braking action is necessary for effective disengagement. Ultimately, achieving this function in a standard sprag clutch design remains problematic.
Stormer
All types of sprag overrunning clutches have some sort of spring to keep the rollers or sprags in contact with the running surfaces so they can engage and wedge to lock the two surfaces together when turning in the locking direction. But is there any kind of sprag clutch where you can dissenguage the overrunning clutch function (when not under load)? Seams like a pretty easy thing to do, but i have not seen any sprag clutch made with this function.
Look at the recoil starter (search the term) on a small engine.
That is just a normal sprag clutch. Not what i am asking for.
If you take control over the engagement of a sprag clutch, it ceases to be a sprag clutch. Will you independently lock or free the directional sprag clutch?
It is normal to select between two shaft speeds using two friction or dog clutches. The complexity and cost can be reduced by replacing the slower clutch with a sprag clutch, that will also prevent a locked condition when both are engaged.
My goal is to make my DIY ebike be able to roll backwards freely when the motor is not powered. On most crank / middrive ebikes there is a sprag clutch between the motor drive and the crank so one does not cause drag for the other. But this causes the motor to drag when trying to roll the bike backwards. So I want a sprag clutch that works like normally as long as the motor is powered, and that fully release in both directions when the motor is not powered via some solenoid or something like that to release the sprag tension.
Just having a ring or something like that to push against the sprags to back them up against the spring tension maybe 1mm would disengage them form the running surface and achieve this, but it is difficult to do in a normal sprag clutch that is not made to have this function. So i think it is strange that i can not find any sprag clutches that have this function built in.
I will not add a separate clutch to do this function because that would take up to much space.
When engaged and transmitting torque, the clutch will be locked solid, and you will not be able to force a disengagement. You will need to unload the clutch first.
You could use two sprag clutches in series opposition, and lock one or the other, rather than unlock one sprag clutch.
Yes as I say in the opening post I only need it to disengage when it is unloaded. Because the bike is standing still when i am going to roll it back to get it out of my basement or off the transport i'm on.
That would take up even more space than adding a additional clutch to disengage the sprag clutch. And it would serve no function because if I could unlock one sprag clutch that is all that is needed, you don't need to add another one.
That appears to be a Sprag clutch, combined with a dog clutch.
Yea, it does.
Ultimately, there needs to be either a manually operated clutch somewhere in the drivetrain, or any braking action within the motor/drivetrain be disabled.
The only possibility I see for a clutch is something that moves axially to disengage.
Think the starter on your car, or the coaster brake built into the rear hub of a single-speed bicycle, or the clutch on a manual-shift car.
  • · Replies 21 ·
11K
14K
