Square roots of positive numbers
For positive real numbers a and b, if λ² = ab, then λ can be both positive and negative, represented as λ = ±√(ab). The confusion arises from the interpretation of the square root; while the square root of a positive number is positive, squaring either a positive or negative number yields the same result. For example, if a = 1 and b = 4, then λ² = 4, leading to λ = ±2. This illustrates that both the positive and negative roots are valid solutions. Understanding this concept clarifies the presence of negatives in the square root equation.
bluskies
If a and b are positive real numbers, and \lambda^{2} = ab, then \lambda = \pm \sqrt{ab}.
None.
This is more of a conceptual question that has always escaped me. I do not understand how the square root of two positive numbers could possibly be negative. Since a and b are positive, how can there be any negatives in the square root of their product? Any guidance on this subject would be very much appreciated.
(-1)2 =1
so squaring -√(ab) will give (ab) regardless of a + or - before the square root.
I think you might be looking too hard into this. There are no negatives in the square root. the negative is outside it. say both a and b are 5. then lambda² = 25. lambda therefore is equal to positive root(25) or negative root(25). Or in other terms, lambda² = 5² or (-5)²
A numerical example can illustrate this. Let a = 1 and b = 4 for instance. Then we have \lambda^{2} = 4. We realize however, that because negatives cancel upon multiplication, in fact (-2)^2 = 2^(2) = 4, and so both -2 and 2 are possible solutions.
Thank y'all for your help, that makes sense now. :)
