SR830 Lock In Amplifier Not Reading Reference Signal
The SR830 lock-in amplifier is not detecting the reference signal, which is confirmed by the "Unlock" light indicating a 1 kHz frequency, while the oscilloscope shows the correct signal at 336 Hz. The reference input voltage was measured at only 140 mV, below the required minimum of 400 mV peak-to-peak, leading to a switch in the detector to achieve the necessary voltage. Suggestions for stabilizing the output voltage include reducing noise, increasing the input signal amplitude, adjusting the sensitivity range, increasing the time constant, and using input filters. Proper setup and signal conditions are crucial for the lock-in amplifier to function effectively. The discussion highlights the importance of ensuring adequate reference signal levels for successful operation.
dkuljis
So here is my dilemma:
We have our SR830 in a MOKE set-up. The modulation of the laser is with a chopper at approximataly 336 Hz. The reference signal is not being picked up by the SR830, but using the same cable the reference frequency is coming up on our oscilloscope. ie, plug the cable into the oscilloscope or DMM and we get the appropriate frequency. Plug it into the SR830, and the "Unlock" light is on with a frequency of exactly 1 kHz, which my adviser says it means it's not getting a signal. The rest of the SR830 seems to be in good working order. Both CH1 and CH2 are picking up signals from our photo detector. Any thoughts or suggestions?
Sorry if the post is skim on details, I'm new to all this.
Thanks for your time,
Danny
"The SR810 and SR830 Lock-In Amplifiers have differential inputs with 6 nV/√Hz input noise. The input impedance is 10 MΩ, and minimum full-scale input voltage sensitivity is 2 nV. "
WOW that's some instrument.
The reference input needs to be 400mV pp minimum. You didn't mention what the voltage is.
Has the setup ever worked?
Does the instrument work in other setups with an external reference?
Can you drive the external reference with a signal generator to test its acquisition range?
Just guessing.
Thanks meBigGuy. We measured the voltage on the reference signal and it was only around 140 mV so we switched our detector and got the reference frequency where it should be. Thanks a bunch for the quick response!Sent from my iPhone using Physics Forums
I am measuring voltage output from the pick-up coils of a vibrating sample magnetometer using the SR830 lock-in amplifier. The problem is that the channel 1 output voltage cannot be stabilized at all. I read the manual but that is not helpful either. What can I do to stabilize the reading ?
*Reduce the amount of noise in your measurement setup. Lock-ins can "cut through" quite a lot of noise, but there are always limits and this should always be the first step
*Increase the amplitude of the input signal
*Make sure you have the SR830 is on the optimal sensitivity range
*Increase the time constant
*Turn on the filters on the input.
Generally speaking, there will always be some trade-off between measurement speed and sensitivity; if your noise is mainly white you can detect some very small signals with a lock-in if you increase the time constant.
Likes Sakin_EEE and berkeman
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
