Srednicki's Lehmann-Kallen propagator derivation doubt
The discussion centers on a doubt regarding the ordering of integrals in the derivation of the Lehmann-Kallen propagator in Srednicki's textbook. A key issue arises from the spectral density being a function of 'k', which complicates the interchange of integrals. Participants suggest that retaining the spectral density inside the momentum integral is crucial for the proof's validity. It is noted that while the original proof may contain errors, the final result remains correct, and an alternative identity can be derived. Clarifications and insights are shared, emphasizing the importance of Lorentz invariance in the spectral density's treatment.
msid
Problem with the ordering of integrals in the derivation of the Lehmann-Kaller form of the exact propagator in Srednicki's book.
We start with the definition of the exact propagator in terms of the 2-point correlation function and introduce the complete set of momentum eigenstates and then define a certain spectral density in terms of a delta function. But the spectral density is also a function of 'k', so we cannot take the spectral density outside the integral over 'k'. Since that is not possible, the subsequent manipulations fail too.
In Srednicki's book :
Equation 13.11 and 13.12
If that is incorrect, the use of 13.15 to get 13.16 is not possible.
I don't see how it is possibe to derive the equation without that interchange.
I'd appreciate any clarifications on this issue. Am I missing some trivial thing?
I don't have Srednicki's text, could you post the relevant equations?
Luckily, the author has a free draft version of the textbook on his website. The relevant contents are the same.
http://www.physics.ucsb.edu/~mark/qft.html
Pg 107-108
Eqns 13.11, 13.12 and the use of 13.15 to get 13.16
I am new to the Physics forum, so I appologise if I doing something wrong by digging up an old thread. I too got stuck at this proof for a while. Now I think I have figured out the correction to the proof. I thought I will share it with others.
There seems to be a mistake in the proof. But the final result is correct.
Instead of rearranging the integrals as Srednicki has done in equation 13.12, retain ρ inside the momentum integral.
1) Now, convince yourself that ρ is independent of the spatial direction of k.
2) Do the time ordering similar to the one in 13.13 and 13.14 but now retaining ρ inside the k integral.
3) The author has used equation 13.15 which is proved in chapter 8. However this is not applicable anymore because ρ is present. However one can obtain an identity similar to the identity 13.15. In this, each integral has an additional function F(|\vec{k}|) inside. Proof is on the lines of the proof of 13.15. Try it.
4) Inserting the new identity you arrive at 13.16
Hope this helps. BTW let me know if there is flaw in my new proof. :)
Ignore my previous post. Equation 13.12 is correct.
Heres the explanation:
rho(s) is invariant under Lorentz transformation because, we have summed over all the possibilities for n.
Since rho is invariant under LorentzTransformations, it can depend only on k^2=k_\mu \eta^{\mu\nu} k_\nu=M^2. But then k^2 is effectively equal to s due to the dirac delta.
Since rho is independent of k, it can be taken out of the integral!
Likes gaboroszkar
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
