Stainless steel as ferromagnetic or non/paramagnetic
Stainless steel exhibits varying magnetic properties based on its composition and crystal structure. Martensitic, duplex, and ferritic stainless steels are generally magnetic due to their bct/bcc and bcc structures, while austenitic stainless steel is typically non-magnetic due to its fcc structure and higher nickel and manganese content. The magnetic properties can change if the stainless steel is cut or ground. The chromium content in stainless steel is crucial for its corrosion resistance, forming a protective chromia film. Understanding these distinctions is essential for applications involving magnetic properties in stainless steel.
abdulbadii
TL;DR Summary
this stainless steel ferromagnetic while that one is non/paramagnetic ?
Why is this stainless steel ferromagnetic while that one is non/paramagnetic, how's each proportion of them and what's its key difference that'd determines such the distinction?
What has your research on the subject turned up? What are your ideas on the subject?
Martensitic, duplex and ferritic stainless steels are magnetic, while austenitic stainless steel is usually non-magnetic.
https://en.wikipedia.org/wiki/Stainless_steel#Magnetism
Fridge magnets work on the stainless steel used to make "white goods" because it is martensitic.
If you cut or grind stainless steel, it will often change its local magnetic properties.
Likes David Lewis, Vanadium 50, berkeman and 2 others
Martensitic and ferritic stainless steels have bct/bcc and bcc crystal structure, respectively, while duplex, as the term implies, has two crystal structures, which could be ferritic-martensitic (F/M), austenitic-ferritic, or austenitic-martensitic. Non-magnetic austenitic stainless steel (usually with a fair amount of Ni and Mn, which are austenite stabilizers) has an fcc crystal structure. The more bcc in an fcc matrix, the more magnetic a stainless steel.
The significance of stainless is the Cr content, which allows a steel to become stainless through the formation of a stable chromia (Cr2O3) film on the surface, which prevents or retards further oxidation/corrosion.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
