Standard electrode potential vs ionization energy
The discussion revolves around the complexities of electrode potentials and the energy changes involved when metals like strontium and cesium ionize and interact with hydrogen in electrochemical reactions. It highlights the difference between ionization energies measured in gas phase and reduction potentials measured in aqueous solutions, emphasizing that the electron transfer is not a simple process. The role of solvents and electrolytes is acknowledged, with a focus on how they influence the energy dynamics during ionization and hydration. Additionally, there is clarification on the common interchangeability of H+ and H3O+, noting that the actual species in solution is more complex. Overall, the conversation underscores the importance of considering multiple factors, including solvation energy, when analyzing these reactions.
Tiiba
Here is the Wikipedia page on electrode potentials. Here's how I'm reading it, which makes no sense:
If a singly ionized atom of strontium donates an electron to the hydrogen in the standard hydrogen electrode, this will emit 4.101 eV of heat (395.68 kJ/mol). If cesium is used, there will be 3.026 eV (291.96 kJ/mol).
Now, what I thought this involves is, you take an electron from strontium (549.5 kJ/mol) and give it to hydrogen (1312 kJ/mol) for a net gain of 762.5 kJ/mol. With cesium, the ionization energy is 375.7, so you should gain 936.3 kJ/mol.
Where is the rest of it, and why is strontium higher?
I understand these are half-reactions, but I don't understand what a half-reaction is.
Chemistry news on Phys.org
Reduction potentials are generally measured in aqueous solutions, while ionization energies are measured in the gas phase.
Likes HelloCthulhu and Charles Link
To add to what @TeethWhitener said, there will be an energy change for the atom on the electrode as it becomes an ion in the solution=the binding energy of the atom to the electrode needs to be overcome. On the receiving end, the hydrogen (ion) comes out of solution and usually results in the diatomic form of hydrogen gas.
I thought the electrolyte probably plays a role, but I wasn't sure what that role is. And also had a hard time picturing what is going on.
So the electron isn't simply moved from one atom to another. The metal goes from M (s) to M+ (aq), so it would break the bonds it had in the crystal, but also form new bonds with water. And the hydrogen does its own version of that. Is that about right?
But how do you get strontium to be +1? As far as I know, it always goes to +2 in water.
Also, when they write H+, do they really mean H3O+?
The valence of +2 is something I didn't consider, but if it is +2, the energy for the reaction would need to be specified as per mole of electrons or per mole of strontium. The table has two entries for Sr. One for ## Sr^{+1} ## and one for ## Sr^{+2} ##. The ## Sr^{+2} ## has a potential of -2.899.
Beware: not electrolyte (although it can be of importance as well) but a solvent is what is the first thing to consider here.
Yes, they are sometimes used interchangeably. Note, that H3O+ is actually not correct - in reality proton is surrounded by several water molecules, so the real formula is something like H(H2O)n+. This is actually a series of compounds in equilibrium with each other, from what I remember n takes values up to 5 or 6.
Now, take into account energy released by each water molecule attracted by the proton, and imagine the same thing happening to the metal ions (we say they are solvated, or hydrated). These energies can be quite large (think how concentrated sulfuric acid gets hot on dilution, think how anhydrous CaCl2 gets hot when dissolved) - do you see why it is not enough to speak just about the ionization energies?
Likes Charles Link
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
