B Stars massive enough to evolve into black holes
The discussion centers on the mass required for stars to evolve into black holes, highlighting that only stars with original masses exceeding 20 solar masses typically result in black holes after supernova events. The remnant mass after a supernova must exceed 3-4 solar masses for a black hole to form, which suggests that a smaller fraction of stars, around 3%, will ultimately become black holes. The majority of stars, including the sun, are less massive and will not end their lives as black holes. It is noted that while massive stars are rare and short-lived, the Milky Way likely contains many old neutron stars and black holes from previous generations of massive stars. Understanding the complexities of stellar evolution and mass loss during supernovae is crucial for accurately estimating the distribution of black holes in the universe.
DaveC426913
TL;DR Summary
How much of the universe will consist of black holes in the future?
I keep seeing this figure of 3-4 Solar masses is all that's required for a star to end its life by collapsing into a black hole.
Since the sun is a pretty average star, that would suggest that most of the stars in the universe (like >50%) will end their lives as a black hole.
The implication is that the universe of the future will be have more black holes than stars, give or take.I went to check my figures before posting and came across this passage on Wiki:
"The result is one of the various types of compact star. Which type forms depends on the mass of the remnant of the original star left if the outer layers have been blown away (for example, in a Type II supernova). The mass of the remnant, the collapsed object that survives the explosion, can be substantially less than that of the original star. Remnants exceeding 5 M☉ are produced by stars that were over 20 M☉ before the collapse.
If the mass of the remnant exceeds about 3–4 M☉ (the Tolman–Oppenheimer–Volkoff limit), either because the original star was very heavy or because the remnant collected additional mass through accretion of matter, even the degeneracy pressure of neutrons is insufficient to stop the collapse. No known mechanism (except possibly quark degeneracy pressure, see quark star) is powerful enough to stop the implosion and the object will inevitably collapse to form a black hole."
https://en.wikipedia.org/wiki/Black_hole
Did I just solve my own problem?
The 3-4 Solar masses is the remnant, measured after the supernova explodes. I have never read that salient detail anywhere before.
So, simplistically, only stars of 20 solar masses, give or take, will ultimately become BHs, I guess. A much smaller fraction.
Astronomy news on Phys.org
1 solar mass is not 4 solar masses. (And as you said yourself, even 4 solar masses isn't even 4 solar masses.
1 solar mass is a big star. See the plot below (from Jim Brau at Oregon):
Likes Frimus and jim mcnamara
What I meant was, if you gathered all the stars that are > 3-4 Sols, you would have a fraction of stars somewhere near half.
Apparently not, as this excellent chart makes quite plain - it's 3%.
Vanadium 50 said:
I had not thought that Sol was among an exclusive group of stars as measured by size (I mean, I knew dwarfs were the most common, but it didn't occur to me to that that meant everything else would be that ... rare. Duh.)
So, stars of solar mass or larger represent (8%+3%+1%) ~12% of all stars.
And then 4+ Sols is only (12%-8%) ~40% of that.
And then 20+ Sols is only a tiny sliver of that.
Wow. Your answer to my question is all wrapped up with a bow and ribbon!
The large ones don't last long:
Jay Maron
Likes DaveC426913
In the neighbourhood of Sun, Sun is in less than 10 % of brightest stars:
https://en.wikipedia.org/wiki/List_of_nearest_stars_and_brown_dwarfs
Sun in number 4 (behind Sirius A, Procyon A and Alpha Centauri A) of about 66. Barnard´s star is actually close to average (about half of all stars are dimmer, half are brighter)... and has less than one thousandth the brightness of Sun.
However, a problem with the star counts is than unspecified star counts tend to be star counts at present. Stars as big as Sun and smaller last the age of the world so far, thus the distribution by mass has always been the same. Not so with massive stars. Bright massive stars are rare but this is at least partly because they are short lived - true, a minimum of 2 million years by Eddington limit, but this is a small fraction of the age of Milky Way. The Milky Way must contain old and cold neutron stars and black holes of many generations of briefly bright stars. Does anyone have numbers for the old massive star remains, compared to lighter stars?
The mass required for BH formation isn't the clear cut, also depends on star composition and the type of supernova. It's possible that very large mass stars leave neutron stars rather than blacks holes, or even no remnant at all - depends how much mass is lost in the supernova. I have a diagram somewhere... from Woosley et all, 2002, sorry it's not that sharp... Also note this is from models of non-rotating stars.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
