Stat mech derivation: Covarience of energy and pressure
The discussion focuses on deriving the covariance of energy and pressure in the canonical ensemble, specifically proving the equation relating average energy, internal energy, and pressure. Participants clarify the definitions of variables, such as energy (E), internal energy (U), microstate pressure (p), and average pressure (p̄). There are debates about the correct forms of equations and the implications of taking derivatives, emphasizing the need for careful handling of averages and microstate values. Suggestions are made to derive the microcanonical pressure and relate it to the average pressure through appropriate substitutions and calculations. Ultimately, the goal is to establish a clear relationship between these thermodynamic quantities using statistical mechanics principles.
swmmr1928
Prove for the canonical ensemble
##\overline{(E-U)(p-\overline{p})}=kT[(\frac{\partial U} {\partial V})_{N,T} + p]##
Left hand side is covariance
E is energy
U is internal energy, average of E
p is microstate pressure
$$\overline{p}$$ is average pressure
V is volume
N is number of particles
T is temperature
##P=-\frac{\partial{U}} {\partial{V}}##
##P=kT(\frac{\partial{ln Q}}{\partial V})##
##U=kT^2(\frac{\partial{ln Q}}{\partial V})##
##\overline{(E-U)(p-\overline{p})}=Cov(E,p)=\overline{E*p}-\overline{E}*\overline{p}=\overline{E*p}-U*\overline{p}##
##\overline{E*p}=?##
##E(E*P)=\sum\nolimits_{i=1}^n E_i P_i p_i = U \sum\nolimits_{i=1}^n P_i=U*P##
Because
##U = \sum\nolimits_{i=1}^n E_i p_i##
##U(p-\overline{p})=kT[(\frac{\partial U} {\partial V})_{N,T} + p]##
hi there! in the first equation:
the ##p## on the right-hand side should really be a ##\overline{p}##. Also, for the relevant equations, I agree with:
(and to keep your notation consistent, maybe it's best to just call it ##\overline{p}##). But I think the equation for ##U## is very suspicious:
I don't trust this at all, since it would imply that the internal energy is simply the average pressure, multiplied by temperature.
Anyway, for the actual answer, you've written
I'm guessing the far left-hand side is "expectation of microcanonical energy, times microcanonical pressure" ? Good, that is the main thing you need to calculate. And the second expression is correct. But I don't trust the third expression. I'm pretty sure that it is not OK to simply take ##U## out of the sum here. Since for each "i", the values of ##E_i## and ##P_i## will be different, this means you can't take one of them out of the sum, as if it were constant throughout the sum. In other words, doing this:
\sum\nolimits_{i=1}^n E_i P_i p_i = ( \sum\nolimits_{i=1}^n E_i p_i ) ( \sum\nolimits_{i=1}^n P_i )
is not allowed. For doing this problem, I think the most important "relevant equation" should be the expression for the microcanonical pressure, in terms of the microcanonical energy. Also, it might be easier to start from
and then work your way back from there. but you can do it whichever way makes more sense to you.
edit: p.s. for the expression of the microcanonical pressure, in terms of the microcanonical energy, this can just be a general kind of equation. You don't need to write down an explicit equation for ##E_i##. But it is important to write ##P_i## in terms of an expression involving ##E_i##. As a hint, it is pretty much the equation you might expect. Hopefully it is in your notes somewhere too.
Correction:
##U=kT^2(\frac{\partial{ln Q}}{\partial T})##
Current Equation:
##\sum\nolimits_{i=1}^n E_i P_i p_i - U*\overline{P}=kT[(\frac{\partial U} {\partial V})_{N,T} + \overline{P}]##
##p_i=\frac{e^{-B*E_i}} {Q(N,V,T)}##
##\overline{P}=kT(\frac{\partial{ln Q}}{\partial V}_{N,T})##
##Q(N,V,T)=\sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}##
##\overline{P(E_i)}=kT(\frac{\partial{ln \sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}}}{\partial V}_{N,T})##
Reduce this to a more general equation?
##\sum\nolimits_{i=1}^n E_i P_i p_i =\sum\nolimits_{i=1}^n E_i*\frac{e^{-B*E_i}} {Q(N,V,T)}*kT(\frac{\partial{ln Q}}{\partial V}_{N,T})##
Integrate over all energies, $$E_i$$ ?For right hand side
A Possible Substitution:
##(\frac{\partial{U}}{\partial V})_{N,T}=T(\frac{\partial{S}}{\partial V})_{T}-P=T(\frac{\partial{P}}{\partial T})_{V}-P##
After Substitution:
##\sum\nolimits_{i=1}^n E_i P_i p_i - U*\overline{P}=kT^2[\frac{\partial{P}}{\partial T}]_{V}##
A different Substitution:
##\overline{P}=-\frac{\partial{U}} {\partial{V}}##
After Substituting:
##\sum\nolimits_{i=1}^n E_i P_i p_i - U*\overline{P}=kT[(\frac{\partial U} {\partial V})_{N,T} -\frac{\partial{U}} {\partial{V}}##
yeah, this is good. So the next step would naturally be to calculate
( \frac{\partial{ln Q}}{\partial V} )_{N,T}
right? I mean, you know everything else on the right-hand side, so hopefully if you can calculate this, you can rearrange into something more familiar.
But where does this equation come from? I don't recognize it..
edit: Oh, I think I see what you meant, something like
U=TS-PV
and so taking partial derivative with respect to volume, while holding only temperature constant:
( \frac{\partial U}{\partial V} )_T = ( \frac{\partial TS}{\partial V} )_T - ( \frac{\partial PV}{\partial V} )_T
But the problem then, is that
is not the same as
P ( \frac{\partial V}{\partial V} )_T
This is not allowed, unless you are assuming that ##P## doesn't change when ##T## is constant.
generally, I don't think it is possible to solve this problem using just thermodynamic relations. It is a stat. mech. problem, after all. It needs you to think about averages, and microstate values.
##Q(N,V,T)=\frac{(q_{trans}*q_{elect}*q_{nuc})^N} {N!}##
##Q(N,V,T)=\frac{(V*A(T,E))^N} {N!}##
##A(T,E)=\frac{q_{elec}(E,T)*q_{trans}(T,V)} {V}##
##\frac{\partial{{ln((V*A(T,E))^N} {N!})}} {\partial{V}}_{N,T}=N/V##
##( \frac{\partial{ln Q}}{\partial V} )_{N,T}=N/V##
ah, that's nice. But that is for a specific kind of system. In fact, that is essentially the ideal gas law ##P=kTN/V##. But I think they are looking for a more general rule.
Also, I was wrong in my last post. sorry, I didn't read carefully enough. When you wrote this equation:
it is not quite right. Because on the right-hand side, you have put the average pressure, but it should be the microcanonical pressure.
You need to have a guess at what the microcanonical pressure is (since I'm guessing it's not in your notes). Try to continue with this equation which you wrote before:
This is the form of ##Q## that I think you should use, try to calculate this partial derivative. And then, compare it to the other way to define ##\overline{p}## (i.e. in terms of its own microcanonical values). From this, you should be able to guess what is the equation for the microcanonical pressure, as some equation involving the microcanonical energy.
Microcanonical ensemble:
##\frac {P} {T}=k\frac{\partial{ln(Ω(N,U,V))}} {\partial{N}}_{U,N}##
Ω(N,V,E) is the degeneracy of of the state N,V,E
by 'microcanonical values' I just mean ##E_i## and ##P_i##. If you write out this equation:
Then you'll get some equation with ##E_i## on the right-hand side. And for the left-hand side, you can use ##\overline{P(P_i)}## to write it out in terms of the ##P_i##. So then, you should be able to guess at how ##E_i## and ##P_i## are related.
edit: To clarify, for the left-hand side, you should just write it in terms of probabilities ##p_i## and microcanonical pressure values ##P_i##.
second edit: I guess I should call them "microstate values" instead of "microcanonical values" to have the correct terminology.
So to find the microcanonical pressure, I should find the average pressure by taking that derivative and comparing it to the average pressure using probabilities:
Average Pressure as a pdf
##\overline P = \sum\nolimits_{i=1}^n p_i * P_i(E_i)##
Average Pressure from Q
When I take this derivative, there is no V, so it equals zero? Or do I use:
##E_i(V)= \sum\nolimits_{i=1}^n \frac{-βh^2(l_x^2+l_y^2+l_z^2)} {8mV^{2/3}}##
Edit, To get:
##\frac{\partial{ln(V^{-2/3}*A)}} {\partial V}_{N,T}=\frac{-2} {3*V}##
yeah, that's it :) And for the right-hand side, just get to:
( \frac{\partial E_i}{\partial V} )_T
you don't need to write it out explicitly (in fact, you can't write it out explicitly, since they haven't told you what kind of system it is). Anyway, once you get to here, you should compare both sides of the equation, then you should be able to guess the equation for the microstate pressure. And then from there, you have enough information to do the question.
So I compare these:
##\overline P = \sum\nolimits_{i=1}^n p_i * P_i(E_i)=( \frac{\partial E_i}{\partial V} )_T####p_i\overset{still true?}=\frac{e^{-B*E_i}} {Q(N,V,T)}##
hehe, yes this is true. But this:
kT(\frac{\partial{ln \sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}}}{\partial V}_{N,T}) = ( \frac{\partial E_i}{\partial V} )_T
is not true. But it is true that the right hand-side will contain terms with
Once you have done the calculation (i.e. use product rule). Then you can compare both sides to guess the equation for the microstate pressure ##P_i##.
Why use product rule? Besides E_i, what else is a function of Volume?
edit: Nevermind, I use:
1/f(x) * d/dx (f(x)) a form of product rule
##\frac {1} {\sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}} * ( \frac{\partial \sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}}{\partial V} )_T##
yeah, that's what I meant. and yes, sorry I think the name is chain rule, I got the name mixed up. But anyway, you've done it the correct way. Next is to use chain rule again, on each of the terms in that sum.
##\frac{\partial \sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}}{\partial V}=\sum\nolimits_{i=1}^n e^{\frac{-E_i} {kT}}*\frac {\partial {E_i}} {\partial V} * \frac {-1} {kT}##
A guess:
##P_i=\frac {\partial{ln(E_i)}} {\partial V}##
yep, that's it! So now, compare to the left-hand side
and you can make a guess for how to write the microstate pressure ##P_i##.
ah, I think you made another post just before me. Uh, it's very close. There should be a minus sign if you check it again.
edit: also are you sure it has ##ln(E_i)## ?
on the right hand side, the sums cancel:
##\sum\nolimits_{i=1}^n p_i * P_i(E_i) = \frac {-1} {kT} * {\frac {\partial {E_i}} {\partial V} }_T##
##P_i=-\frac {\partial E_i} {\partial V}##
An equation we are given is: ##{\frac {\partial A} {\partial V}}_T=-P##
Where A is Helmholtz Energy
edit: I'm talking about your post #22 here
yeah! that's it. Although really, the sums don't cancel, it is technically just a guess. But since they don't give you ##P_i## In the question, I think you had to make this guess. At least it is a fairly sensible guess. So anyway, now that you have ##P_i##, you can prove the expression they gave:
So, from here, the two 'unfamiliar' things are
( \frac{\partial U} {\partial V})_{N,T}
and
So now, using your equation
you can try to see how these 'unfamiliar' terms are related.
uh, they are both derivatives with respect to V?
you mean the two 'unfamiliar' terms? You need to write them out explicitly to see how they are related. they are not just equal to each other, since there are other terms in the big equation which you are trying to prove is true.
##\sum\nolimits_{i=1}^n -\frac {\partial E_i} {\partial V}*E_i*p_i=\sum\nolimits_{i=1}^n -\frac {\partial E_i} {\partial V}*E_i*\frac {e^{-β*E_i}} {Q(N,V,T)}##
##{\frac {\partial U} {\partial V}}_{N,T}##
##U=\frac{\sum\nolimits_{i=1}^n E_i*e^{-E_i/kT}} {Q}##
##Q=\sum\nolimits_{i=1}^n e^{-E_i/kT}##
##\frac {\partial} {\partial V} { {\sum\nolimits_{i=1}^n E_i*e^{-E_i/kT}} *1/e^{-E_i/kT}}=##
##\frac {\partial} {\partial V} { {\sum\nolimits_{i=1}^n E_i}}##
##{\frac {\partial U} {\partial V}}_{N,T}=\frac {\partial} {\partial V} { {\sum\nolimits_{i=1}^n E_i}}##
yep. good so far. keep going. Although I think it is easier to write ##U## directly in terms of ##E_i##, and then do the partial differential with respect to ##V##.
Compare this ##\sum\nolimits_{i=1}^n E_i *(-\frac {\partial E_i} {\partial V})*p_i## to ##{\frac {\partial U} {\partial V}}_{N,T}=\frac {\partial} {\partial V} { {\sum\nolimits_{i=1}^n E_i}}##
##\sum\nolimits_{i=1}^n \frac {\partial E_i} {\partial V} ##
These terms include the same derivative, where on the first line, it is multiplied by ##-E_i*p_i=U##
hmm. hold on, this:
is not quite right. The right-hand side is missing the probabilities that go with each of the microstate energies ##E_i##
  • #31
Instead it is ##\frac {\partial {\sum\nolimits_{i=1}^n E_i p_i}} {\partial V}##
And the other ##\sum\nolimits_{i=1}^n E_i p_i*(-\frac {\partial E_i} {\partial V})##
Can these be differentialted?
If both the probability and energy are functions of Volume, i can use product rule
  • #32
If I use the expression for U that expresses the probability in E_i and exp(-BE_i) and Q(N,V,T) then Product and quotient rule?
  • #33
yep. you should differentiate the first one, using product rule. And the second one, you can just leave it as it is. It is fine like that.
  • #34
##p_i \frac {\partial E_i} {\partial V} + E_i \frac {\partial p_i} {\partial V}##
##p_i=exp(-B*E_i)/Q(N,T,V)=exp(-B*E_i)/exp(-B*E_i)##
##\frac {\partial p_i} {\partial V}=0##
##\frac {\partial {\sum\nolimits_{i=1}^n E_i p_i}} {\partial V}=\sum\nolimits_{i=1}^n p_i \frac {\partial E_i} {\partial V}##
  • #35
The first equality is correct. But the second equality is definitely not correct. ##Q## is a completely separate sum, not the same sum. So you need to use another product rule here. You're getting there, though. So, try using product rule on the middle expression:
##exp(-B*E_i)/Q(N,T,V)##
  • #36
## \frac {\partial p_i} {\partial V}=exp(-B*E_i)*\frac {\partial} {\partial V} \frac{1} {Q} + 1/Q* \frac {\partial exp(-B*E_i)} {\partial V}##
## \frac {\partial exp(-B*E_i)} {\partial V}= exp(-B*E_i)*(-B)* \frac{\partial E_i}{ \partial V}##
This B will hopefully cancel the kT
Sum of ##\frac {\partial} {\partial V} exp(B E_i)=exp(B E_i)*B*E_i##
  • #37
yep, that's it! keep going with it
  • #38
##\frac {\partial p_i} {\partial V}=B*E_i-(B/Q)*e^{-B*E_i}*\frac {\partial E_i} {\partial V}##
  • #39
that's not quite right. I agree with the second term on the right-hand side. But I don't agree with the first term on the right-hand side.
In your previous post, the first term on the right-hand side was this:
I'm pretty sure this does not become ##BE_i##
  • #40
##e^{-B*E_i}*\frac {\partial} {\partial V} \frac {1} {\sum\nolimits_{j=1}^n e^{-B*E_j}}=e^{-B*E_i}*\frac {\partial} {\partial V} \sum\nolimits_{j=1}^n e^{B*E_j}=
e^{-B*E_i}*\sum\nolimits_{j=1}^n B*e^{B*E_j}*\frac {\partial E_j} {\partial V}##
Edit: Maybe I should avoid expressing Q explicitly
##\frac {\partial} {\partial V}\frac {1} {Q(V)}= -\frac {\partial Q} {\partial V} * Q^{-2}##
## E_i*\frac {\partial p_i} {\partial V}=\frac {-E_i*e^{-B*E_i}} {Q}[{\frac {1}{Q} * \frac {\partial Q} {\partial V} + B*\frac {\partial E} {\partial V}}] ##
## \frac {1} {Q} * \frac {\partial Q} {\partial V} = \frac {\partial ln(Q)} {\partial V}##
## E_i*\frac {\partial p_i} {\partial V}=\frac {-E_i*e^{-B*E_i}} {Q}[ \frac {\partial ln(Q)} {\partial V} + B*\frac {\partial E} {\partial V}]=-p_i E_i*[ \frac {\partial ln(Q)} {\partial V} + B*\frac {\partial E} {\partial V}] ##
  • #41
yep. very nice. and you can use your equation for
##\frac {\partial E} {\partial V}##
(but remember, this should be ##E_i## not ##E##). And also, in your relevant equations section on the first post, you have an equation for
##\frac {\partial ln(Q)} {\partial V}##
So then you should be able to write out the whole term as something 'nicer'. And then you can start to prove the equation that they asked for.
  • #42
## \frac {\partial ln(Q)} {\partial V}=\overline{P}*β ##
## \frac {\partial E_i} {\partial V}=-\overline{P} ##
## \sum\nolimits_{i=1}^n E_i p_i *(-\frac {\partial E_i} {\partial V}) - U*\overline{P}=kT*[{\overline{P}+\sum\nolimits_{i=1}^n p_i*\frac {\partial E_i} {\partial V}}-p_i*E_i*[\frac {\partial lnQ}{\partial V}+B*\frac {\partial E} {\partial V}]]##
## \sum\nolimits_{i=1}^n -E_i p_i \overline{P} - U*\overline{P}=1/B*[{\overline{P}-\sum\nolimits_{i=1}^n p_i*\overline{P}}-p_i*E_i*[\overline{P}*B-B\overline{P}]]##
  • #43
yep. Although, to keep notation consistent, It's probably best to write ##\overline{p}##. Anyway, you can stat to calculate all the terms now, and see how they all go together to prove the statement that you were given to prove.
  • #44
##\sum\nolimits_{i=1}^n -E_i p_i \overline{P} - U*\overline{P}=1/B*[{\overline{P}-\sum\nolimits_{i=1}^n p_i*\overline{P}}]##Wrong:
##-\overline{P}[\sum\nolimits_{i=1}^n E_i p_i + U]=1/B*[{\overline{P}}-\sum\nolimits_{i=1}^n p_i*\overline{P}]##
##-\overline{P}[\sum\nolimits_{i=1}^n E_i p_i + U]=1/B*[{\overline{P}}-\overline{P}]##
## 2*U*\overline{P} =0 ##
Edit: Do you see my error?
  • #45
I'll back up:
## E_i*\frac {\partial p_i} {\partial V}=-p_i E_i*[ \frac {\partial ln(Q)} {\partial V} + B*\frac {\partial E} {\partial V}]=-p_i E_i*[ B*\overline{P} - B*\overline{P}] =0 ##Right?
  • #46
This is not quite correct. The correct equation is in your post #22.
uggh.. It is kinda difficult to follow. In the previous posts, you were trying to find:
and you got to
( \frac{\partial U}{\partial V} )_T = \sum_i p_i ( \frac{\partial E_i}{\partial V} )_T + \sum_i ( \frac{\partial p_i}{\partial V} )_T E_i
And then you found that
E_i ( \frac{\partial p_i}{\partial V} )_T = -p_i E_i ( \overline{P} \beta + \beta ( \frac{\partial E_i}{\partial V} )_i )
Generally, it is best not to do too many steps at once, So maybe the next best step is to simply write out:
using these equations. (and don't be surprised if it contains any terms with ##\overline{EP}##).
  • #47
##\frac {\partial U} {\partial V}_T=\sum\nolimits_{i=1}^n \frac {\partial E_i*p_i} {\partial V}\overset{Product rule}=\sum\nolimits_{i=1}^n E_i\frac {\partial p_i} {\partial V}+p_i\frac {\partial E_i} {\partial V}##
##E_i*\frac {\partial p_i} {\partial V}\overset{From post 40}=-p_i E_i*[ \frac {\partial ln(Q)} {\partial V} + B*\frac {\partial E_i} {\partial V}]\overset{using sub. 2 and 3}=##
##-p_i E_i B[ \overline{P} - P_i]=-p_i E_i B \overline{P} + P_i p_i E_i B\overset{sub. 1}=-p_i E_i B \overline{P} + B\overline{P E}##
##\frac {\partial U} {\partial V}_T=\sum\nolimits_{i=1}^n -p_i E_i β \overline{P} + β\overline{P E}+p_i\frac {\partial E_i} {\partial V}##
##\sum\nolimits_{i=1}^n -p_i E_i β \overline{P} + β\overline{P E}+p_i\frac {\partial E_i} {\partial V}\overset{sub. 3}=\sum\nolimits_{i=1}^n -p_i E_i β \overline{P} + β\overline{P E}-p_i P_i##
## \sum\nolimits_{i=1}^n -p_i E_i β \overline{P} + β\overline{P E}-p_i P_i \overset{sub. 4,5}= \sum\nolimits_{i=1}^n -β U \overline{P} + β\overline{P E}-\overline{P}##
Substitutions Used:
1) ##E(E*P)=\sum\nolimits_{i=1}^n E_i P_i p_i##
2) ##\overline{P}=kT(\frac{\partial{ln Q}}{\partial V})=(\frac{\partial{ln Q}}{\partial V})/B##
3) ##P_i=-\frac {\partial E_i} {\partial V}##
4) ##U=\sum\nolimits_{i=1}^n p_i E_i##
5) ##\overline{P}=\sum\nolimits_{i=1}^n p_i P_i##
Back to the full equation:
##\overline{(E-U)(p-\overline{p})}=kT[(\frac{\partial U} {\partial V})_{N,T} + \overline{p}]##
##\overline{EP}-U*\overline{P}=kT[\sum\nolimits_{i=1}^n -β U \overline{P} + β\overline{P E}]##
  • #48
ah, very nice. nice and clear working, too. nice work. It's quite a lot of steps really. uh, in the last line you've left in the summation sign, but the summation has already happened. I'm guessing this is just because you copied and pasted the text and changed some of the text, but not all? (i.e. typing error). So anyway, looks good.
Likes 1 person
