Statement in Cohen-Tanoudji I don't understand
  • Thread starter Thread starter quasar987
In finite-dimensional spaces, the dual space X^* and the state space X are isomorphic due to the Riesz representation theorem, which states that every linear functional can be represented as an inner product with an element from the space. This creates a bijection between the elements of X and their corresponding linear functionals in X^*. The cardinality of X and X^* being equal does not imply they have the same dimension, but the image of a basis in X under this bijection forms a basis in X^*. In finite dimensions, the algebraic dual and topological dual coincide, reinforcing the isomorphism. Thus, the isomorphic relationship holds true in finite-dimensional contexts.
quasar987
He writes, talking about the ket space X of a physical system,
In general, the dual space X^* and the state space X are not isomorphic, except of course, if X is finite dimensional.
Can someone explain why they are isom. in the event of finite dimensionality?
For instance, say X is finite. To every |x> in X is associated the linear functional &lt;x| (the "inner product functional"). But also, given any (non-identity) linear operator A on X, <x|A is a new linear functionnal on X, is it not*? So that makes the cardinality of X^* greater than the cardinality of X, so there can be no bijection between them.
What's wrong?*I should say potentially new, because if A maps every |x1> towards |x2>'s such that, by miracle, <x|x1>=<x|x2>, then <x| and <x|A really are the same functional...
I don't get it. That dual is the algebraic dual or the topological dual ? (In the case of finite dim. LTS they coincide, so it doesn't matter.)
How can you infer that " the cardinality of X^{*} is greater than the cardinality of X" based on what you've written ?
Daniel.
Ok, my counter-exemple's not good. But my main question remains. Why are X and it's dual isomorphic in the even that X is finite dimensional?
(The dual X^* is the set of all linear functionals on X.. I guess that's the algebraic dual?)
In a Hilbert space you can show every linear functional arises as the inner product with some element in the space. There's your bijection. Of course, having the same cardinality does not entail having the same dimension, but you can show the image of a basis in the space under this bijection is a basis in the dual space.
For complex Hilbert spaces, X and X' ( with X' the topological dual) are isometrically complex conjugate isomorphic, by the Riesz representation theorem.
If the Hilbert space is finite dimensional, then the topological dual and the algebraic dual coincide and the isometric complex conjugate isomorphism is obviously still valid.
If your initial space X was not a linear topological space, but merely a finite dimensional linear space, then you'd have to go back to the linear algebra course and search for a method to prove the complex conjugate isomorphism.
Daniel.
  • · Replies 0 ·
  • · Replies 32 ·
