Static Analysis for SAP2000 API
  • Thread starter person123
In summary, the SAP2000 API can be used to create structural models in python, but static analysis is not possible using the documentation.
person123
328
52
TL;DR Summary
I found the SAP2000 API useful for modeling a complex structure, but without static analysis there's a lot of friction. Is there a way it could be added?
For background, SAP2000 is a structural analysis software used in industry a lot and it has an API in several languages that seems to talk to a SAP2000 executable. It be used to create structural models as an alternative (though I think infrequently used) to the GUI.I started using the SAP2000 API for modeling a complex structure and I found it very helpful. I could have a record of everything that made the model, loop through repetitions in the structure, quickly update it with different parameters, and have calculations for the structure's geometry in the code directly. However, while there is good documentation, I found a big source of friction was that python (the language I'm using) couldn't do a static analysis with that documentation. (I can't see the component classes and methods of a component class, nor the arguments of a method in the IDE itself like most libraries). This means I have to search the documentation separately, copy over the method I want (often there's 3 or 4 layers of component classes), and count the arguments to check what they each refer to (there's often many arguments, some irrelevant). Then to review the arguments I passed I have to either wrap the call in a function I wrote, add a comment or just remember it. If this friction was removed, I think using the API would be faster and more robust than using the GUI in general.
Could there be a way to get static analysis of the classes and methods?
One approach I thought of is parsing through the documentation (a chm file) to get name, description and arguments of each method. Then I would generate python classes with an identical composition hierarchy who have methods that just call an API method with an identical name. It would then appear identical to calling the API method directly but static analysis would come with it. It sounds like a crazy idea to me (writing code to write code and wrapping an API in essentially another API), but I think it should work.
Would there be a better and simpler way of doing it? Are there issues with the way I'm proposing? Might there already be a way of getting static analysis?
Thanks!
Technology news on Phys.org
I don't understand the term "static analysis" in the way you are using it. To me static analysis is performed by tools like pylint and I don't think that is what you want.
No, it's not a crazy idea, that's exactly what you (or someone else) needs to do (if it has not been done already by the vendor or someone else).
Likes person123
Thank you!
Yes, I'm probably not using the term static analysis correctly. What I want to see are the list of component classes and methods of a class, and the arguments of a method, you often see in IDEs. Would they just be called tooltips instead? (I was calling it static analysis because it tells you things about your program without running it).
Sounds good, I think I'll look around a bit more to see if it's been done, and if not, I'll do it myself. I've never really done anything like it and it felt like a strange approach, so it's very good to know it's fairly standard. (I'm not contacting CSI directly since I only have a work account and I'm not sure if I can use it to ask about things only tangentially related to my job).
Update:
I added the tooltips with the method I described, with a demo attached. The documentation isn't perfect -- small format mistakes prevented me from constructing about 10% of the methods, and you can even see typos in the demo (e.g. SapMdel instead of SapModel). I could fix these issues manually though.
Likes pbuk
FAQ: Static Analysis for SAP2000 API
What is Static Analysis for SAP2000 API?
Static Analysis for SAP2000 API is a method used to analyze the structural behavior of a building or any structure under static loads. It involves determining the stresses, strains, and deformations in the structure without considering the effects of dynamic loads or time-dependent behavior.
How is Static Analysis for SAP2000 API different from Dynamic Analysis?
Static Analysis for SAP2000 API focuses on analyzing the structure under static loads, while Dynamic Analysis considers the effects of dynamic loads such as earthquakes, wind, and vibrations. Static Analysis is simpler and faster than Dynamic Analysis but may not capture the full behavior of the structure under dynamic loads.
What are the steps involved in performing Static Analysis for SAP2000 API?
The steps involved in performing Static Analysis for SAP2000 API include defining the structural model, applying loads and boundary conditions, solving the equations of equilibrium, and analyzing the results to determine the stresses, strains, and deformations in the structure.
What are the advantages of using Static Analysis for SAP2000 API?
Some advantages of using Static Analysis for SAP2000 API include its simplicity, efficiency, and ability to provide quick results. It is also useful for analyzing structures that are predominantly subjected to static loads and do not require consideration of dynamic effects.
Are there any limitations to Static Analysis for SAP2000 API?
One limitation of Static Analysis for SAP2000 API is that it does not account for the effects of dynamic loads, which may be significant in certain structures. It also assumes linear behavior of materials and may not capture the full nonlinear response of the structure under extreme conditions.
