Static Equilibrium and tension of cables
A 30 kg neon sign is suspended by two cables, with three 5 kg cats adding weight. The center of mass was calculated as (1.11m, 0.278m) using coordinates for the sign and cats. The tension in each cable was initially assumed equal, leading to an incorrect result of 245N. By summing torques about the base of the sign, the tension in the second cable was found to be 250.8N, allowing the first cable's tension to be calculated as 190.4N. The calculations were confirmed as correct by multiple participants in the discussion.
Juniper7
A 30Kg neon sign is suspended by two cables, as shown. Three neighbourhood cats (5.0 Kg each) find the sign a comfortable place. Calculate the tension in each cable with the cats are in the positions shown.
xCM = m1x1 + m2x2 ...
mtotal
yCM = m1y1 + m2y2 ...
mtotal
F = mg
I found the centre of mass (CM) by assigning each cat a coordinate using the bottom left corner of the sign as the origin with (x,y). So:
Cat1 = (0.2,0.5)
Cat2 = (1.8,0.5)
Cat3 = (2,0)
Sign = (1,0.25) --> the centre of the sign
Using the above two equations I found the centre of mass of the cats and sign to be (1.11m,0.278m)
There should be no forces in the x-axis and the forces in the y-axis should all cancel out so:
T1cable + T2cable = mg
I know the position of each cable from the picture so: (using only y-axis position)
T1(0.5m) + T2(0.5m) = (45kg)(9.81)(0.278m)
The tension in each cable should be equal? Or, because one cable is farther from the CM it should have less tension? Does this mean I should be taking into account the x axis? Please help!
Looks like you y'd when you should have x'd. Torque is force times perpendicular distance from line of action of force to any point chosen wisely.
Hm ok. So:
T1(0.2m) + T2(1.8m) = (45kg)(9.81m/s2)(1.11m)
T = 245N
So that means each cord has a tension of 245N?
Juniper7 said:
Hm ok. So:
T = 245N
No, your equation was ok but then you assumed that T1 and T2 were equal and got an erroneous result. To simplify matters, try summing torques not about your assumed origin at (0,0), but rather, about the point at the base of the sign at coordinate (0.2,0). You can choose any point, but keep it simple. In this manner, you can solve for T2 directly, because there will be no torque from T1, then continue...
Ok. So coordinates for each point would be in relation to (0.2,0) If I do it how you suggest:
T1(0m) + T2(1.6m) = (45kg)(9.81m/s2)(0.91m)
T2 = 250.8N
Then can I use my earlier equation to solve for T1?
0.2T1 + (250.8N)(1.8m) = (45kg)(9.81m/s2)(1.11m)
T1 = 190.4N
You look to be correct. I worked it out separately and got this result, so I hope you're right :p.
yes, looks good!
Thanks!
