Static pressure tubes vs pitot tubes
  • Thread starter Thread starter Chris J
L-shaped tubes with side holes are preferred for measuring static pressure in ducts because they minimize the influence of boundary layer effects and duct surface roughness. This design allows for more accurate readings by positioning the measurement point away from the duct wall, which can distort results if a simple side connection is used. While a direct connection could yield reasonable measurements, it may not be as reliable without additional probes. The L-shaped configuration also facilitates access to deeper areas within the duct for comprehensive pressure assessments. Accurate static pressure measurement is crucial for effective HVAC system performance.
Chris J
I've noticed when measuring static pressure in a duct most people use L shaped tubes with small holes in the sides, very similar to a pitot tube except it's missing the hole in the end for dynamic pressure.
What is the reason for using an L tube with holes in the sides for static pressure alone? Wouldn't just a connection into the side of the duct generally provide a fairly accurate measurement?
It should, but it would require a second hole and probe. I've also seen L shaped static pressure probes though, and I think they want to be a little away from the side of the duct so there's no weird effects from the boundary layer or roughness.
https://www.contractingbusiness.com/service/article/21212881/secrets-of-the-static-pressure-tip
Likes jack action and Chris J
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
