Static sphere with gravitating fluid
In summary, the study of a static sphere with gravitating fluid explores the equilibrium state of a fluid contained within a spherical boundary under the influence of gravitational forces. This system is characterized by the balance between gravitational attraction and fluid pressure, leading to specific mathematical models that describe the fluid's behavior and distribution. The analysis often involves solving differential equations that govern the fluid dynamics and gravitational interactions, providing insights into astrophysical phenomena, such as star formation and the structure of celestial bodies.
VincentIsoz78
Hi
The rotating bucket problem with a fluid is well known as a homework. For the fun i wanted to adapt it to the case of a massive non-rotating sphere surrounded by a fluid. However i don't know if the calculations i made are correct or don't make sense at all (even if the result lead to an intuitive conclusion).
Here is how i did it:
Let us consider a volume of fluid of uniform density put beside a material sphere of mass ##M## and radius ##R## and such that the volume of the fluid is very small in comparison of the material sphere (i.e. the sphere is surrounded by the liquid). We assume to be under the incompressibility assumption and steady flow and we neglect the self-gravity of the fluid!
Based on our assumption, the Euler equation :
[tex]\dfrac{\partial \vec{v}}{\partial t}+(\vec{v} \circ \vec{\nabla}) \vec{v}=-\vec{\nabla} \dfrac{p}{\rho}+\vec{g}[/tex]
reduces to (as we are interested of what happens when the fluid is static !) :
[tex]\vec{0}=-\vec{\nabla} \dfrac{p}{\rho}+\vec{g} \Leftrightarrow \vec{\nabla} p=\rho \vec{g}[/tex]
Now we know very well that we have outside of the material sphere:
[tex]g(r)=\dfrac{GM}{r^2}[/tex]
Then the Euler equation can be expressed as (using the gradient in spherical coordinates) :
[tex]\dfrac{\partial p}{\partial r}=\rho \dfrac{G M}{r^2}[/tex]
Integrating we get :
[tex]p=-\rho \dfrac{G M}{r}+C^{t e}[/tex]
Given ##p=c^{\text {te }}## at a free surface, we have :
[tex]r=\dfrac{C^{t e}-c^{t e}}{\rho G M}=\dfrac{k}{\rho G M}[/tex]
Let us put ##c:=k /(\rho G M)##. Therefore we get :
And this is the equation of a sphere in spherical coordinates! Hence the final shape of a fluid surrounding a material sphere is itself a sphere.
What are you thoughts? If this is the wrong place to ask for feedbacks let me know where i could post the above development instead.
Thanks
MENTOR NOTE to POSTER:
We use Mathjax for rendering Latex expressions:
- mathjax keys on double $ quotes for expressions on their own line
- mathjax keys on double # quotes for expressions embedded in text
Adjusted some of your expressions from single $ quoted to double # quoted.
Likes Dale
Wow, I expected a dodecahedron!
  • Haha
Likes Vanadium 50 and VincentIsoz78
LoL The idea was the prove it using maths for fun and not just claim it.
Since the setup has spherical symmetry, a non-spherical result would violate rotational invariance of space.
I also don't see the final equation after: "Therefore we get :" Maybe the Mod adjusting the Mathjax quotes dropped it?
Likes Vanadium 50
Actually, non-spherical solutions are permitted, so long as the set of all solutions has spherical symmetry. But I agree with your point (which can also be shown to be correct in this case.)
Likes jbriggs444
The missing part removed by the Mod is
$$r=c$$.
I get your point about rotation invariance. But that's the same for the rotating bucket that you deal in cylindric coordinates and therefore you get obviously a parabola as a result and not a hyperbola.
However my question remains. Does the proof makes sense or is it just good for the garbage?
The rotating bucket has axial symmetry, and there are infinitely many axially symmetric surfaces, so you have to derive the right one. Your setup has spherical symmetry, so there is only one possible surface.
FAQ: Static sphere with gravitating fluid
1. What is a static sphere with gravitating fluid?
A static sphere with gravitating fluid refers to a theoretical model in astrophysics where a fluid is contained within a spherical volume, and the system is in a state of hydrostatic equilibrium. This means that the gravitational forces acting on the fluid are balanced by the pressure gradient within the fluid, resulting in a stable configuration.
2. What are the key equations used to describe a static sphere with gravitating fluid?
The primary equations used to describe a static sphere with gravitating fluid include the hydrostatic equilibrium equation, which relates pressure and density within the fluid, and the Poisson equation, which describes the gravitational potential. The Tolman-Oppenheimer-Volkoff (TOV) equation is also crucial for understanding the balance of forces in such a system, particularly in the context of general relativity.
3. How does the concept of a static sphere apply to astrophysical objects?
The concept of a static sphere with gravitating fluid is applicable to various astrophysical objects, including stars, planets, and gaseous nebulae. In stars, for instance, the balance between gravitational collapse and internal pressure from nuclear fusion can be modeled using this framework. It helps in understanding the stability and structure of these celestial bodies.
4. What are the stability conditions for a static sphere with gravitating fluid?
The stability conditions for a static sphere with gravitating fluid depend on factors such as the equation of state of the fluid, the density profile, and the specific gravitational forces involved. Generally, the system is stable if small perturbations do not grow over time, which can be analyzed using criteria like the von Neumann stability analysis or linear perturbation theory.
5. What are some real-world implications of studying static spheres with gravitating fluid?
Studying static spheres with gravitating fluid has significant implications for our understanding of stellar evolution, the formation of planets, and the dynamics of galaxies. It provides insights into the lifecycle of stars, the conditions necessary for star formation, and the behavior of fluid dynamics in gravitational fields, which are essential for modeling cosmic phenomena.
