Statics question: when do I need to find the support reactions?
Understanding when to find support reactions in statics is crucial for applying the Method of Joints and Method of Sections effectively. It's generally recommended to calculate support reactions first, as this provides known external forces that simplify the analysis. While zero force members can be ignored in certain cases, having the support reactions aids in accurately determining forces in the structure. Many resources are available online to further clarify these concepts. Overall, solving for support reactions early in the process is beneficial for a clearer and more manageable solution.
denting
I didn't use the format because my question is more general. I want to be able to understand the logic so I can apply it where appropriate.
We're finding forces (and whether they're in tension or compression) using the Method of Joints and Method of Sections. I don't understand why sometimes it's necessary to find the supprt reactions, but sometimes it's not. Please help. Thank you!
I know in the method of joints there are certain joints that can be ignored called "zero force members" as the name implies. Since the question is so general I'm not sure if this is at all what you are looking for. Theres plenty of reference material on the internet to help you out though I am sure.
It is almost always better to solve for the support reactions first before using the method of joints or sections, because it gives you more known external forces up front and makes the solution much easier. Sooner or later you'll need to find them anyway, better sooner than later.
I always solve for reactions first as well.
PhanthomJay, I was looking forward to hearing your take on the question.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
